F6 Amplifier
F6 Amplifier
Old 6th December 2019, 03:37 AM   #6631
meanie is offline meanie  Singapore
Hi TungstenAudio,
Is that a direct swap?
Anything needs to be done on the front end?
I am on +/- 25.4Vdc, recently bias up to 1.35A, sound pretty good than before. Please share with us your mods.
Originally Posted by TungstenAudio View Post
Iím using FQH44N10 instead of IRFP150. Finally fired up my F6 today, and am impressed with how great it sounds. Iíve pushed the power rails to 26.4V, with 1.42 Amps of quiescent current for now. The power supplies and heat sinks are designed to support 1.8 Amps of current if that proves beneficial.
Marantz 7 clone - BA3FE - Yarra/Melbourne Preamp - USSPA - Korg Nutube - BabyHuey EL34s - 2ACAs - F6 - M2XSLB - 2Whammy -
USSA5SLB
Old 6th December 2019, 03:40 AM   #6632
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
I’m using FQH44N10 instead of IRFP150. Finally fired up my F6 today, and am impressed with how great it sounds. I’ve pushed the power rails to 26.4V, with 1.42 Amps of quiescent current for now. The power supplies and heat sinks are designed to support 1.8 Amps of current if that proves beneficial.
Yeah these are great devices in this application, the 150V FQA28N15 parts are also great.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 6th December 2019, 03:45 AM   #6633
Originally Posted by meanie View Post
Hi TungstenAudio,
Nothing will need to be done. at most maybe swapping out biasing Zener references but unlikely.
Old 6th December 2019, 03:48 AM   #6634
More current more good.
hahaha
Old 6th December 2019, 04:24 AM   #6635
TungstenAudio is offline TungstenAudio  United States
Nothing special needed to support the FQH parts. I am using LM329 voltage references in place of the zener diodes, but I would have used those anyway.
The higher voltage called for a different input buffer, so I implemented a Diamond buffer very similar to the Austin input stage of the M2x.
Old 6th December 2019, 08:50 AM   #6636
zman01 is offline zman01  Bangladesh
F6 Amplifier
TA,
Congratulations on your successful tweaks and thank you for sharing.
However, these are a bunch of mods you've implemented at the same time:
1. Brand new input buffer
2. Higher voltage power rails
3. Higher bias
4. Different MOSFETs (to handle higher bias)
Questions:
1. Would ~26V be too high for the default 2SK170/SJ74? I recall reading somewhere that 26-27V would be ok (I might be wrong)?
2. Even if we keep ~24-25V voltage rails, the sound is expected to "improve" at higher bias for MOSFETs (IRF or others)?
3. Any measurements to show what changed in the THD level or harmonic profile?
Old 6th December 2019, 12:27 PM   #6637
They are drop in devices, along with many other mosfets.
I did answer this early but as usual no one ever listens to what I say.
Hahaha
26 Volts is fine provided Idss of the jfets aren't too high, keep them below 8mA, or mount heatsinks on the jfets.
Old 6th December 2019, 05:05 PM   #6638
My build of the F6 does have a number of modifications from the standard circuit and PSU which are documented in the F6 Illustrated Build Guide. Partly because of that, this build has taken me longer to complete as I worked through a couple issues related to initial prototypes.
This amp has been inspired by several fairly diverse sources, including the M2x, a couple Bablefish designs and some of the original F6 discussions in this thread. To a lesser extent I also tried to use parts that I have acquired over the last year or so for other ideas. In large part, the main goal of this amp was to use a set of FQH44N10 parts that I discovered while looking for parts similar to the IRFP140 and IRFP150. The FQH parts looked very good on paper, and I'm happy to say I'm very pleased with how they sound as well. In order to best support the parametric performance of the FQH Mosfets, I made several other changes to the main board design of the F6:
1. Power supply voltages were increased to a target range of 26 to 27 Volts.
2. Quiescent currents were increased to a target range of 1.4 to 1.8 Amps.
3. Source resistances at the output stage were lowered to 0.50 Ohms for R1 and 0.40 Ohms for R2.
4. The low side of C1 was connected directly to the ouput node, rather than the Source of Q1. C2 is connected as specified by the F6 Mosfet DIY schematic.
5. Z1 and Z2 were replaced by LM329, 6.9V voltage sources. R7 and R8 were lowered to 4.3 kΩ.
6. The simple input buffer was replaced by a Diamond buffer inspired by the Austin input stage of the M2x.
7. The SLB power supplies available from one of the group buys are used with Antek AS-3222 power transformers.
So, I really have no idea what a stock F6 sounds like, in either power JFet or Mosfet configuration. I do really like what I'm hearing out of my build so far. Following an overnight thermal soak, another short listening session this morning showed that the amp has changed very little from the couple hours after initial power up in my system. I still have a lot more listening to do and some measurements to make. As it stands, this F6 is giving my Aleph J a run for its money, which says a lot. The two amps have different characters, and it would be difficult to choose a favorite.
I can say that I intend to follow up on some ideas I have regarding the power supply. It has been my experience that Cap Mx types of supplies often benefit from large bulk capacitors in the 10 mF to 20 mF range (10,000 uF to 20,000 uF) to better support low frequency performance in the bottom octave or two. I will try this over the next day or two after I've hooked the amp up to my HP 339A to take some baseline measurements. I will also be increasing the quiescent current, probably before adding the big power supply caps.
Old 8th December 2019, 02:51 AM   #6639
BruceInOz is offline BruceInOz  Australia
Ordering a transformer for F6 build. Which would be the best choice?
VA CORE CODE CORE SIZE OD mm HT mm WT kg REG %
300 H 60/100/40 110 58 2.6 6
300 X7 60/110/40 120 58 3.0 5
400 TLP 80/180/20 190 37 5.0 6.5
400 T 60/110/40 120 57 3.0 6
500 I 60/125/45 135 63 4.5 5
Sorry about the formatting - looks great in preview....
Old 8th December 2019, 04:54 AM   #6640
F6 Amplifier
BruceInOz,
Assuming single transformer and a CRC power supply similar to the one available at the diyAudio store, 300VA - 400VA with 2 ◊ 18V AC secondaries shiuld be fine.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 05:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 09:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 08:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 09:38 AM
F6 traw Pass Labs 7 2nd November 2007 08:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
