F6 Amplifier
F6 Amplifier
Old 30th November 2019, 05:26 PM   #6611
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F6 Amplifier
I would expect the light to go bright charging up the caps, and then dim while the
bias voltage is developed and then glow dim when the amp is running.
Old 1st December 2019, 12:59 PM   #6612
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
If you are using the diyaudio store power supply pcb be sure that any washers used to mount the pcb on standoffs do not also short the power supply rail to the amp chassis and to earth.
The rail output holes are very close to the pcb mounting holes (too close actually) a largish washer will make contact with the power supply rail if you’re not super careful.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 2nd December 2019, 10:16 AM   #6613
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by enser View Post
Just wrapped up 2 x F6 beasties. Excellent sounding even at break in~ 90% bias. Going to ramp them up today
Had some RIFA/Kemet PEH169 100,000uf caps that needed a home, and they got it.
These bridges - hope the current does not have to travel though iron
la recherche d'un son perdu
Old 2nd December 2019, 11:34 AM   #6614
Prologue is offline Prologue  Belgium
Hello,
I have a 17v sec toroidal transformer, would it be a problem to use it in my F6 build ?
Old 2nd December 2019, 12:29 PM   #6615
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
just go for it
volt up or down is not so important , as quality and VA of Donut
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 2nd December 2019, 02:15 PM   #6616
Originally Posted by Zen Mod View Post
just go for it
Thanks !
Old 4th December 2019, 09:20 AM   #6617
kpsthakur is offline kpsthakur  India
Thank you so much Mr. Pass. Well, too a leap of faith and started the amp directly, I was anyway using a 40W bulb which seemed reasonably less for this test, and there was almost no DC at output, the LED's looked fine...so power on, music on, everyone's happy. F6 back in business
Merry Christmas everyone
Old 5th December 2019, 10:36 AM   #6618
BruceInOz is offline BruceInOz  Australia
Hello F6 Community & Nelson Pass,
Would appreciate your guidance on whether or not this amp would successfully drive / be a good match for my Martin Logan Ethos hybrid electrostatic speakers. The bass driver of these speakers has it's own in-built dedicated amp so the F6 would power the panels only.
I ask because the impedance curve is funky with a low 1 ohm dip albeit at 18kHz - see attached.
92dB / 2.82v /m sensitivity
nominal impedance 4 ohms
Thank you
Old 5th December 2019, 11:50 AM   #6619
Zen Mod's Avatar
F6 Amplifier
just go for it
Old 5th December 2019, 06:03 PM   #6620
The one and only
F6 Amplifier
Pretty tough load at the top, but try it anyway.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 05:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 09:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 08:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 09:38 AM
F6 traw Pass Labs 7 2nd November 2007 08:09 PM
Copyright ©1999-2019 diyAudio
