Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 6th April 2020, 11:25 PM   #8631
dweightman is offline dweightman  United States
Default ACA with Korg B1
Its not too much of a squeeze, most challenging issue is fitting the volume pot to a 10mm thick front panel. It does make a very neat integrated and I haven't experienced any heart or vibration problems. I do use separate power supplies for
the Kong and the ACA, mainly so that I can turn the ACA off and leave the Kong on constantly. In my case a single source amp is fine...tried to attach images but failed miserably. It all fits in a 2U ACA Dissipante chassis
Old 7th April 2020, 07:56 AM   #8632
Roo2 is offline Roo2  Australia
Thanks Gary. Yes, definitely looking into that premium thread. Thanks also dweightman. Ill probably do a very ventilated perforated enclosure like my AlephJ. Perhaps add an internal heat shield to segregate the Korg.
Cheers
Old 12th April 2020, 09:20 AM   #8633
Saracenblue is offline Saracenblue  United Kingdom
Default Keratherm Brown
I purchased some Keratherm Brown insulating pads as they were readily available in the UK. However, they are not easy to use because they are so, so thin (overall thickness 0.27mm with the plastic protective sheet being 0.02mm thick). I just can't seem to peel the sheet off.
Looking further into this product, it is also inferior regarding its' thermal conductivity, only 1.4 W/mK compared the the Keratherm Red 6.5.
Wondering if anyone has successfully used the brown or whether it would be best for me to get some mica and paste instead?
Graham
Old 12th April 2020, 12:07 PM   #8634
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
Keratherm Red is only one which you can use, as better than mica + goop
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th April 2020, 12:40 PM   #8635
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
how about Kapton tape? i plan on using them....
if people react to you a certain way, it is not because of them but more because of you....
Old 12th April 2020, 01:06 PM   #8636
Thanks ZM,
I was afraid that might be the response.
Hi Tony,
Thanks, I'll check out Kapton tape.
Graham
Old 12th April 2020, 01:34 PM   #8637
Zen Mod's Avatar
Amp Camp Amp - ACA
for ACA, mica is mooooooooore than adequate
take in account that (most) FW amps are having exactly that
Keratherm is really needed only when you're approaching 35++ W of heat per device
Old 12th April 2020, 01:35 PM   #8638
Skylar88 is offline Skylar88  South Africa
Skylar88's Avatar
Here's an idea; Since Keratherm is so thin, it may help to prepare the mating surfaces by making sure there are no sharp edges or protrusions. Light sanding with very fine sandpaper on a flat surface may be all that's needed to prevent pinched spots.
Edit: And I agree with ZM. Mica is perfect for ACA. That is what I used in my ACA.
B1, ACA, AKSA Lender Pre, H2 V1, Dual 3FE25-16 0.53X Karlsonators
Old 12th April 2020, 06:53 PM   #8639
Thanks guys,
Mica will work for me.
Found a TO-3PL package size (29 x 22mm) that should do the job but I am confused by the description 'mica insulation sheet.....) then down the page, Material-plastic. ???
Thought it best to ask as I don't want to get it wrong again.
Also any special requirements regarding the type of insulating compound?
This all new to me.
Graham
Old 12th April 2020, 07:34 PM   #8640
Zen Mod's Avatar
Amp Camp Amp - ACA
find on-line what you think that's real thing, then post links here
best way of learning
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
