Amp Camp Amp - ACA
Amp Camp Amp - ACA
Amp Camp Amp - ACA Please consider donating to help us continue to serve you.
Old 2nd December 2019, 07:33 PM   #8271
Mooly's Avatar
Amp Camp Amp - ACA
The ACA does make a noise as the DC conditions momentarily stabilise and the large speaker coupling cap charges.
I did a theoretical investigation into this a little while back although a simple relay delay on the speaker feed is all that is needed to make it silent.
A possible approach to adding a silent start/shutdown to the ACA
Old 2nd December 2019, 08:54 PM   #8272
TungstenAudio is offline TungstenAudio  United States
Use two ACAs in one of their monoblock configurations. The PSU induced warbles cancel each other out almost perfectly. Problem solved
Old 2nd December 2019, 08:57 PM   #8273
Extreme_Boky is offline Extreme_Boky
I was surprised how well this worked in a balanced configuration.
Old 3rd December 2019, 01:08 AM   #8274
I've been thinking about this one.... the reason there's no startup fart/switchoff thump in balanced mode is the fact that speakers' outputs are not referenced to ground. There's no potential difference between two outputs (minuses) at any point in time during turnon/off - hence no complaints from speakers.
...I've got rusty...
Old 3rd December 2019, 01:41 AM   #8275
6L6 is offline 6L6  United States
6L6's Avatar
Amp Camp Amp - ACA
Thump totally normal. See post 50 of the build guide -
Amp Camp Amp V1.6 Build Guide - diyAudio Guides
Old 3rd December 2019, 02:39 AM   #8276
That's okay for a single chassis, stereo ACA version, but we are not talking about that...
What we observed was the absence of startup fart/turnoff thump due to transition occurrences that are happening between two identical ACA modules at the same point in time, and the fact that speakers' binding post are not referenced to ground.
Old 3rd December 2019, 03:49 AM   #8277
6L6's Avatar
Amp Camp Amp - ACA
I’m sorry, extremeBoky, for not being more specific, I was responding to rob755 and his question about the thump on a single ACA in post #8278.
Old 3rd December 2019, 03:59 AM   #8278
Goodness me no need to apologise!
Nick
Old 6th December 2019, 03:49 AM   #8279
rob755 is offline rob755  United States
Thanks so much. Very much appreciated!
Old 8th December 2019, 08:59 AM   #8280
lifefordota is offline lifefordota
How ACA convert to be headphone amp? Is there any modifications?
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 04:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 03:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 05:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 07:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
