Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old Yesterday, 09:05 AM   #8081
MEPER is offline MEPER  Denmark
MEPER's Avatar
Originally Posted by spiggs View Post
The speakers used in the review were 86db sensitive and 8 ohm, my speakers are 88db sensitive 8 ohm full rangers plus I have 3db of BSC filter. They go beyond what I consider loud listening in my living room. Distortion or no what is so fundamentally different from my setup to what the tester used?
This was also the part of the review I found most strange. The tester should redo this test and measure on speaker input if he gets full signal. A 5V RMS signal on 86 dB speakers should be louder than just background music?
Old Yesterday, 10:18 AM   #8082
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Amp Camp Amp - ACA
Room size and listening distance change sufficient power thresholds a lot. Listening habits are a significant factor as well. Users of high power amps usually listen loud and uncompressed in bigger rooms with moderate efficiency speakers of larger voice coils poised for sufficient replay of also EDM and other power loving genres.
Old Yesterday, 10:29 AM   #8083
starbender is offline starbender
I used my ACA with fifty years old philips full range drivers. I was using B1 at that time.. And it was magical.. Unfortunately I don't have full rangers anymore for listening because of WAF issues (really big boxes!)....
I also used ACA with 87db three ways and used BA3 pre and it still delivers enough juice for speakers..
I think reviewer doesn't have enough input level to get sufficient spl.
Old Yesterday, 10:39 AM   #8084
Salas's Avatar
Amp Camp Amp - ACA
ACA should be at its dynamic best on 95dB SPL/W/M speakers or more. Never pushed beyond 2-3V RMS output so it gives a moderate oomph of harmonic coloring in subjectively high enough peaks while getting progressively resolving in fade outs. Its blacker background than most tube amps and going to its linear best the other way than most higher SINAD performance solid state amps should be its two trick pony mojo.
Old Yesterday, 02:34 PM   #8085
lifefordota is offline lifefordota
is there any difference of so called
voltage hungry and current hungry speaker or amplifier design?
what about this ACA
Old Yesterday, 02:56 PM   #8086
PMA is offline PMA  Europe
PMA's Avatar
Yes there is, you will find it in speaker sensitivity and in speaker impedance/frequency plot. ACA would excel neither in voltage swing, nor in current supplied.
Old Yesterday, 08:13 PM   #8087
batty is offline batty  Australia
ACA works very well with Castle Howard 1/4 wave 2.5 way speakers, they are a nominal 8 ohm load of 92dB sensitivity.
I have gone from 85 watts class AB amplification to an ACA.
Old Yesterday, 08:19 PM   #8088
Derekva is offline Derekva  United States
In nearfield, the ACA (old version) works great with Linaeum LFX. In large rooms, plays just fine with Altec and Klipsch.
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 04:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 03:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 05:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 07:04 AM
Copyright ©1999-2019 diyAudio
