Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 21st October 2019, 06:43 PM   #7921
Azookey is offline Azookey  United States
I find myself in a pickle. I love the balanced operation of the monoblocks, I love the distortion cancellation, extra power, etc. I also love my older NAD 1240 preamp. The preamp only has single ended outputs.
I need some opinions, search for a balanced preamp and hope i like it as much as the NAD... or get a DI solution like an ART box and use it with the NAD? What are the thoughts on something like a direct box? Does it alter the signal too much, add anything, etc? If not, any recommendations?
Thanks.
Old 21st October 2019, 08:03 PM   #7922
woody is online now woody
You might look at this .
PassDiy
Old 21st October 2019, 08:09 PM   #7923
Bfpca is offline Bfpca  Canada
Bfpca's Avatar
Amp Camp Amp - ACA
If the DI box is passive and uses transformers you are depending on the box using good quality, transparent transformers. You could also DIY your own balanced to unbalanced converter using Jensen or Cinemag transformers which are known to be transparent. Jensen also makes DI boxes using their transformers but they are quite pricey. The active type DI boxes use op amps, so that is likely not where you want to go with a system having an ACA.
Old 21st October 2019, 08:24 PM   #7924
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
Thanks.
see in build thread and I believe - it must be covered somewhere - ACA is having built in SE to Bridge operation mode ..... thus you need just SE input
see small toggle switch on back of amp
no need for semi-solutions , when existing one is superlative to that
only premium solution (proper balanced preamp or high quality xformer with all impedance issues covered) is better
edit : it will be certainly wiser to toss NAD on curve (making happy some Kido) and build Iron Pumpkin ....... but look at price of that move ......... and it demands proper balanced sources , for full Trip to Heaven
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 21st October 2019, 08:46 PM   #7925
David Garretson is offline David Garretson  United States
I have the ACA 1.6 version and am considering trying a pair of linear power supplies-- possibly the Chinese Zerozone 24V/5A on ebay @$165. I've had good results with the Zerozone in other applications. Just need to confirm the ACA DC input plug size. Is it 2.5mm/ID 5.5mm/OD?
Anyone else compare the Meanwell SMPS to a LPS?
Old 22nd October 2019, 07:08 AM   #7926
Loudthud is offline Loudthud  United States
Loudthud's Avatar
There is a significant THD penalty for using the switch vs balanced drive. See graph below or refer to post 7038 and 7040 in this thread.
Old 22nd October 2019, 08:01 AM   #7927
lifefordota is offline lifefordota
therefore pairing with 8 ohm speaker is still better in overall ? compared to 4 ohm
Old 22nd October 2019, 05:47 PM   #7928
Tomcat1969 is offline Tomcat1969  Scotland
Hi folks. I'm totally new to this. I want to build ACA monoblocks.
My phono.stage is a DIY EAR834. Can I run the ACA's from it?
Thanks guys.
Old 23rd October 2019, 08:05 AM   #7929
Loudthud's Avatar
I'm not sure I understand your question. Bridged mode will provide more power to an 8 or 16 Ohm load compared to what could be achieved by a single channel. For a 4 Ohm load, it's hard to predict and I didn't test with a 4 Ohm load in either Bridged, parallel or normal single channel configuration. Parallel mode would certainly do better with a 4 Ohm load that dips below 4 Ohms like some ESL speaker systems.
In bridged mode with a 4 Ohm load, I would be tempted to increase the idle current to the point allowed by my heatsinks.
Old 23rd October 2019, 08:46 AM   #7930
mc297 is offline mc297  Italy
Let say that the ACA #1 had a 1W 1kHz THD of about 0.7%, what is the distortion of ACA 1.6 at 1W (19V supply)?
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 04:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 03:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 05:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 07:04 AM
Copyright ©1999-2019 diyAudio
