Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 11th August 2019, 10:22 PM   #7701
Mazeppa is offline Mazeppa  United States
Mazeppa's Avatar
Amp Camp Amp - ACA
Originally Posted by alextab View Post
..... an actual loss in fidelity? (and interesting to see my grammar plugin wants to change that to infidelity lol).
Har! Post of the day.
CD transport<Schiit Gungnir Multibit DAC<Iron Pumpkin SE Pre<Aleph J<Tekton Lore Reference
Old 14th August 2019, 06:02 PM   #7702
spiggs is offline spiggs  United States
Default Troubleshooting noise from amp
I am getting noise from the ACA through one channel. Originally I thought it was the pre but have changed everything but the ACA and speakers and still get the noise. Link to thread in analog line level. Note that the noise has gone from left channel to right and back to left as I try to trouble shoot it but for no reason I could figure out. User error in hookup maybe but I did not find anything.
Distortion from preamp
Original posting has a recording attached of the noise. I never notice it when I first turn the amp on, seems to happen after it warms up. I have tried re-flowing solder joints that looked at all questionable. Of course the normal poking to see if moving anything helps. Can't seem to find anything obvious to me but of course this was my first build. Amp is built to v1.6 spec with the exception of .13 uf worth of capacitors on the line in jack to roll off lower freq. It has been in the system for about 6 months and I have noticed the problem just over the last month. Looking for pointers on what to check next, it is driving me a bit nuts 🙁
Old 14th August 2019, 07:00 PM   #7703
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
pics
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 15th August 2019, 03:19 AM   #7704
Originally Posted by Zen Mod View Post
pics
As requested
Old 15th August 2019, 06:46 AM   #7705
Zen Mod's Avatar
Amp Camp Amp - ACA
repair soldering of wires on all terminals
if that doesn't help - replace JFets between channels
if trouble moves following JFet , from channel to channel - you found JFet as culprit
if problem stays on same channel as it was , replace mosfets - they're cheap and easy to get everywhere
re-set output node voltage ( some calls it "BIAS") when doing any change , including swapping of JFets
Old 15th August 2019, 08:49 AM   #7706
MEPER is offline MEPER  Denmark
MEPER's Avatar
You have heard noise from both channels during "testing"?
Have you tried to bypass the caps you have put on input?
This just to start with a "standard" ACA before you modify. The ACA NFB circuit rely on that pre has low impedance. The serial cap at input will influence on that. It may not be the right way to do the "roll of" with this kind of amp design?
If you have a scope it would be helpful to see how the noise looks like......
Old 16th August 2019, 05:40 AM   #7707
Thanks for the advice. I'll get soldering and report back what I find. The noise is only in one channel but I'll try bypassing the input caps as well just to check.
Old 16th August 2019, 09:01 AM   #7708
Stanislav is offline Stanislav  Australia
May I ask why are you rolling off the low freqs?
The cut-off for 0.13uF and 10kOhm is around 120Hz.
Even if you double the Rin the cut-off will be 60Hz
Unless you are using the ACA to drive some MF or HF drivers in an bi-amp setup.
And even then there are better ways to do it.
Just curious...
Old 16th August 2019, 02:01 PM   #7709
Just curious...
I use the ACA to drive a pair of 4" full range drivers and pair that with a subwoofer to handle below 120Hz.
Old 17th August 2019, 03:04 PM   #7710
mraudioguru is offline mraudioguru  United States
I played your sound file and I have the same EXACT noise in the right channel of my amp. It's been there since the beginning, (almost a year now), but I haven't had the time time to fix it...until yesterday.
Mine would only rear it's ugly head once out of every 5 times or so and only on startup for a second or two. Well, it has gotten worse and was time to fix it.
I know this is a very long thread, but 98% of all the problems reported within, were solved by re-flowing solder joints. I was pretty sure that was going to solve my issue and it did! I touched up every solder joint and made sure I had good solid connections.
I also redid a couple of steps, (the build guide was changed during/after it was first completed and a few little changes were made), so mine is now done 100%.
Needless to say, my ACA is now performing perfectly and sounds GREAT. It actually always sounded fine, but now the scratchy, crackly noise is gone!!!
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
Copyright ©1999-2019 diyAudio
