Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 6th July 2019, 12:55 AM   #7601
dfoulk is offline dfoulk
I will do that, but I did notice that on the resistance checks where it shows
335K resistance at the end of R10, I only get around 72K
That is way off, but its odd that the amp worked fine before, and both
of the channels zonked out together.
If the reflow doesn't work, I will post pictures when I have it apart.
Thx
Old 6th July 2019, 03:49 PM   #7602
Amp working fine now. Problem turned out to be the substitution of a different input cap, and the way I implemented it by jumpering C3 position on the board, and putting the new
cap directly off of the input jack. That made the circuit go nuts, unable to set bias at all.
Went back to default cap on board with a polystyrene by-pass added, and all is A-OK!
Old 6th July 2019, 04:53 PM   #7603
bloozestringer is offline bloozestringer  United States
bloozestringer's Avatar
I finally finished my ACA. I set the initial bias to 12V, screwed the bottom cover on and layed the top cover on. Then played some music for 30 minutes or so and reset the bias to 12V again (it hadn’t drifted more than 0.1V). The heat sinks get warm, but I can easily hold my hands on it for 10 seconds and I have wimpy hands Lol. I didn’t see anything in the 1.6 build guide about letting it warm up but assumed it would change. Do I need to check it again? I seldom get to listen for more than an hour at a time, fwiw.
Old 6th July 2019, 04:55 PM   #7604
6L6 is offline 6L6  United States
6L6's Avatar
Amp Camp Amp - ACA
If it's not drifting a bunch between cold and warm (and what you are describing is fine) then you are done. Listen and enjoy!!
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
Copyright ©1999-2019 diyAudio
