Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 25th February 2019, 11:57 PM   #7161
RCV is offline RCV
Default Maximum operating hours
I notice that the ACA gets hot easily. Is there a recommended maximum operating hours for this good sounding amplifier to avoid overheating?
Old 26th February 2019, 12:31 AM   #7162
udailey is offline udailey  United States
Just measure the heatsink temp. Around 50c is okay forever. This was just discussed a page or two back. So there is a bit more info if you search.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 26th February 2019, 12:33 AM   #7163
tjw59 is offline tjw59  United States
Default ACA's and heat
Have run mine 24/7 for periods of weeks. They get to a certain temperature and stay there unless the room ambient temperature changes. Just make sure air can move under them and around them.
Old 26th February 2019, 04:56 AM   #7164
irishpatrick33 is offline irishpatrick33  United States
I know what gauges I need. Can anybody identify what type or brand the wires for the kit are? Or simply identify some quality wire for power, signal, and output?
Old 26th February 2019, 09:17 AM   #7165
RCV is offline RCV
Udailey, thanks!
Old 26th February 2019, 09:18 AM   #7166
RCV is offline RCV
tjw29, thanks!
Old 26th February 2019, 11:36 AM   #7167
billyk is offline billyk  United States
billyk's Avatar
Amp Camp Amp - ACA
I have one of the original kits, I have not shut it off in about 4 years now. Well occasionally it gets shut off to move or clean, but mostly left on.
Old 26th February 2019, 12:51 PM   #7168
RCV is offline RCV
Billy, thanks! It only goes to show how durable the parts are.
Old 26th February 2019, 12:54 PM   #7169
RCV is offline RCV
I am done building my two monoblocks. My Q Acoustics Concept 20s are perfect for the ACA. I have not yet tried them though with the Magnepans.
Old 26th February 2019, 01:28 PM   #7170
astromo is offline astromo  Australia
astromo's Avatar
Bear in mind that I've barely made apprentice amp builder status and that I'm not blessed with golden ears - in my case, I opted for generic offerings. The important factors that I looked out for (after gauge) was (in no particular order):
  • Solid versus multi-strand
  • Tinning of the copper wire strands
  • Temperature rating of the insulation (if you're concerned you can take this to the next level and check the build/design standard)
So, on that basis I landed on multi-strand (less prone to damage due to manipulation), tinning (minimise copper corrosion), temperature rating ca. >=85C (given how warm Class A amps get, it seems sensible to select wire with insulation that can handle a bit of heat, so the higher temp rating the better {within limits, i.e. $$}). Even so, life's a compromise and there are varying shades of grey that will be influenced by personal taste/rationale.
Hook up wire can attract a swag of opinion, e.g.:
Best Hookup Wire? (for component internal wiring)
You could check that thread to gather intel. Probably best to avoid sending this thread on a tangent.
Good luck with your journey.
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 04:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 03:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 05:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 07:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
