Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 19th January 2019, 05:54 PM   #7071
Bfpca is offline Bfpca  Canada
Amp Camp Amp - ACA
Originally Posted by JP14 View Post
Bfpca - unfortunately, I don't have an oscilloscope, but my multimeter (Fluke 115) has a frequency measurement. I'm not sure if that will work, but I'll test tomorrow comparing the working and non-working channels.
If you put your DVM on ac volts you should be able to see the input signal. If it is a test tone it will show up as a low ac voltage. If you are using music as a test signal it will show a low varying ac reading. The DVM frequency range is not really suitable for this test.
Old 20th January 2019, 02:29 PM   #7072
SiliconTi is offline SiliconTi
SiliconTi's Avatar
Does anyone know how I can buy the silver faceplates for the v1.6 kits? I ordered black, but want to change them out.
Old 20th January 2019, 03:20 PM   #7073
bbm3 is offline bbm3  United States
Contact the DIY Audio Store: email:support@diyaudiostore.com
I am pretty sure they can order individual parts from HiFi2000.
Or design your own Front Panel Express: Front Panel Design Software and CAD Conversion Service: Home
Old 20th January 2019, 03:57 PM   #7074
mraudioguru is offline mraudioguru  United States
A short while ago, the DIYAudio Store had these listed separately for sale. Not sure if they were order only, or if they stocked them? But they had several different chassis pieces that could be bought.
Old 21st January 2019, 02:12 AM   #7075
SiliconTi's Avatar
Thanks. I sent an email to contact@, but did not receive a reply. I'll try support@.
Nothing on the site I can find.
Thanks!
Old 21st January 2019, 12:01 PM   #7076
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Amp Camp Amp - ACA
You can try here:
10mm aluminum front panel for Pesante, Dissipante, Slimline or Deluxe – diyAudio Store
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 21st January 2019, 01:48 PM   #7077
SiliconTi's Avatar
Jason got back to me and will send a quote. Thanks!
Old 21st January 2019, 01:50 PM   #7078
SiliconTi's Avatar
Thanks Dennis,
I want it with the ACA engraving and power switch hole too. Thanks for the link though, that is a good backup plan.
Old 22nd January 2019, 04:03 AM   #7079
RafaPolit is offline RafaPolit  Ecuador
RafaPolit's Avatar
Have you checked there isn't a short between the MOSFETs and the heatsink of the affected channel?
The fact that there IS music should say this isn't the place to look... perhaps something else is shorting against the heatsink?
One last swap test: have you changed the inputs to discard source fault?
Old 22nd January 2019, 08:59 AM   #7080
plsvn is offline plsvn  Italy
or... I have two (bought the silver "kit" then changed my mind and, Hi-Fi 2000 being local to me, ordered two black ones)
just drop me a PM if you wish
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 04:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 03:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 05:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 07:04 AM
Copyright ©1999-2019 diyAudio
