Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old Today, 07:39 AM   #6361
MEPER is offline MEPER  Denmark
Originally Posted by Neel007 View Post
This is the wiring in the box:
Attachment 710169
The soldering work looks bad.
A couple of wires looks like they are not soldered at all.
A black wire from the switch and also the resistor from the switch.
You should let the solder flow so the hole is all filled with solder. All solder joints should be nice round and shinny (no sharp edges). Many looks like "cold" solder joints like you use too little temperature. If you use lead free solder this has higher melting point and is more difficult to work with. Use 60/40 solder......
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
