Amp Camp Amp - ACA
An update on my build and a shout out to Solmer. I received my second ACA kit and sucessfuly assembled it. The kit was missing the 4 10uF capacitors and I sent a Email to DIY store and never heard back from them. Never the less I outsourced them and finished the build. and it acually works..So I revisited the first attempt with the loud hum and finally noticed I had assempled the input RCA's wrong with the ground washer against the faceplate. I fixed the problem and now I have monoblcks driving my 2way Cornscallas..
I do have a couple of follow up questions though. I am still confused with the talk of phase reversal. What does that mean for my speaker connects? Also, why are so many audiophiles concerned with speaker wires when the inside wiring from the pcb to the binding posts is what, 20 ga.?
Reactions: 1 user
Administrator
Joined 2007
The ACA inverts phase. All that means is when the input signal goes in a positive direction, the output goes the other way. The speaker cone moves in the opposite directions for an inverting amp vs a non inverting.
There is much controversy over whether it matters or is audible. To correct inverting phase all you do is swap the speakers wires around so - and + are reversed. Can you hear a difference or not?
The ACA circuit itself inverts phase, the ACA as a finished product does not and that is achieved simply by swapping the speaker connections around internally in the amp. The end user is non the wiser.
Reactions: 1 users
My ACAs have the original 19V power supplies. After a recent power outage I am noticing a lot more static through the speakers. I disconnected the source RCAs and it is still noticeable. Next step was to hook it up to a bench supply and determine if the power bricks are the culprit. Anything else to check?
Does this look like enough heat sink for an ACA at 24 volts? 200 x 69 x 36mm.
Joined 2012
Looking at the fins, the spacing of fins is about 69mm/26 = 2.65mm. Clear space between fins is less. For reasonably effective natural convection cooling, the minimum clear space between fins needs to be about 6 or 7mm. Less than that and the air stagnates between the fins, not moving well to transfer heat away from the heat sink.
With closely spaced fins, forced air is needed.
