Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 28th August 2018, 04:54 AM   #5591
RafaPolit is offline RafaPolit  Ecuador
RafaPolit's Avatar
Mpitogo, really nice setup, and really nice seeing the amps share room with some heavy hitters! Thanks for sharing those pics.
I did not experience such a drastic change as days went by... my AMP behaved more or less the same always (which has always been very good). I can hear a bit of difference due to warm up, but since my heat dissipation is a lot less, it may reach that state sooner. Perhaps my other equipment is just less resolving and those changes are not as obvious. It may also be that your ears are simply better than mine!
At any rate, happy to read your story and that it has a happy ending! (Or start, because now you get to enjo.y the music!)
Best regards,
Rafa.
Old 28th August 2018, 04:59 AM   #5592
Socratease is offline Socratease
OK, reassuring to know, thanks!
Old 28th August 2018, 06:52 AM   #5593
Alan4411 is offline Alan4411  Wales
Alan4411's Avatar
Originally Posted by CJ5 Renegade View Post
apparently no shorts to Q1 or Q2 on board #1
however r1, r2, r3 & r4 became extremely hot in short order when board powered up
You have to re do quite a lot under there I think.
As has already been posted, you need to re-flow some solder pads, solder in Q3 and trim the leads to a much shorter length. See how that goes first!
Old 28th August 2018, 07:42 AM   #5594
garybx is online now garybx
As I was building my second amp, I was mounting the rear panel connectors and couldn't remember exactly how to distribute the various insulators, lugs, washers and nuts. So I looked at my first build for reference. I noticed that on the RCA input connectors, I had the lug inserted next to the panel. That prompted me to examine the photos closely and that revealed that they should have been isolated by the insulators. I will probably unsolder them and re-do the order of the hardware, but I am wondering if it really matters if the ground of the RCA connectors are connected to the chassis.
Old 28th August 2018, 07:59 AM   #5595
Extreme_Boky is offline Extreme_Boky
Originally Posted by Zen Mod View Post
well, for Aleph CCS , zener mod is already confirmed to soften a clipping
however , I experienced that my ears are not happy before clipping point of Aleph CCS
so , two ways from there - either build bigger Aleph , or acquire speakers better using power of existing Aleph
example - in my workshop , I'm damn happy with 3W feeding RCA LC1B in MLTL boxes , while for Tannoys in my living room (OB with Beyma 15" bass helper , so diving under 4R down) I'm happy with 10W
Originally Posted by Extreme_Boky View Post
Cool, thanks. I will hook my test gear and play with ACA Vccs to examine its behavior, and will definitely try a zener and then drive the amp to clip to see what happens.
So, the ACA's measured correctly; they did not show any excessive ringing while I was testing them with a tone generator, 6ohm resistor and oscilloscope at around clipping point, so... I figured out what I was doing wrong that caused excessive ringing.
The ACA's have plus speaker binding posts connected to ground, I was connecting my speakers banana plugs to ACA while keeping the spades (bi-wiring) connected to my other amp... and this was, of course, shorting the ACA's negative speaker output (the actual ACA output) to ground via spades and my other amp.
Once I disconnected the spades from my other amp (removed the short), the ACA's showed what they can do.. into 4 ohms, and only 86dB efficient Dynaudio speakers. Great sound, drive, natural presentation. The bass was exceptionally defined with great texture and harmonic faithfulness to the original recording - so hard to achieve, and so underappreciated by many "audiophiles"... Everything sounded natural and relaxed... it reminded me of 2A3 and 45 single-ended tube amps, which I regard highly. There was plenty of power with ACA's. I tried 68K feedback resistor (14dB gain) but did not like the loss in cone control due to a drop in damping factor...
Old 28th August 2018, 08:08 AM   #5596
As a token of appreciation for this great kit and all the hard work that went into preparing everything required to offer it as a full kit, here are some photos of my build. The intention was to get the most out of this two gain stages, pure class A design.
WARNING - I do not recommend placing the SMPS inside the ACA to unexperienced DIY-ers. Please take this warning very seriously.
Old 28th August 2018, 08:10 AM   #5597
Few more...
the last one shows driving my HD650 straight from the speaker output - exceptional sound!
Old 28th August 2018, 08:31 AM   #5598
Sub Sonic is offline Sub Sonic  Australia
Very nice work, and thanks for the photos.
Old 28th August 2018, 08:34 AM   #5599
Mooly's Avatar
Amp Camp Amp - ACA
Originally Posted by cRomer View Post
I set my DMM to 00.0mv it gave me 01.7 Right 01.5 Left. The probes are touching GND and V+. Are these correct?
Thank you.
Not exactly
The idea is to measure the applied AC signal and the AC output level using a DVM to try and see why one of your channels is quieter than the other.
First disconnect the speaker. Now connect just one input socket to your player/preamp because we are testing each channel separately.
1/ Set the meter to AC voltage.
2/ Connect the black lead of the meter to the Red speaker socket (which is ground on the ACA)
3/ Connect the red lead of the meter to the Black speaker socket.
4/ Play the tone and adjust the volume to give a reasonable output voltage on the channel under test. The ACA should be able to easily reach 6 volts rms so aim for that.
(Absolute value is unimportant because we are only comparing readings and also seeing if the gain works out correctly)
Write the result down.
5/ Now transfer the red meter lead to the 'input' side of R11. This is the end that goes to the input wiring and sockets.
6/ Without altering the volume write down the reading you see.
Those two results give you an output voltage and corresponding input voltage. From those two results we can confirm if the board is working correctly.
8/ Without altering any settings now swap the input to the other channel and repeat the test. You should be seeing similar readings of output voltage and input voltage on R11.
Lets see where yours falls down on this.
Old 28th August 2018, 10:22 AM   #5600
Alan4411's Avatar
Originally Posted by Big Cheese View Post
I hope my DMM is up to the task (simple $20 home mart jobby), but this gives me an idea what to looking for - and how to.
Hi Cheese, there was a small error on my original (Q3 upside down DOH). Please use this one. Your meter will be fine, I used a $5 one and get similar results.
Amp Camp Amp - ACA
I will do a similar one for voltages soon.
Alan
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 04:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 03:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 05:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 07:04 AM
