Amp Camp Amp - ACA
Amp Camp Amp - ACA
Thread Tools
Old 14th October 2021, 08:27 PM   #11001
captain pugwash is offline captain pugwash  United Kingdom
45.5 ohms with red lead on G, 45.6 ohms the other way. Thats with the board off of the heatsink
Old 15th October 2021, 06:17 AM   #11002
Mooly's Avatar
Amp Camp Amp - ACA
I'm wondering if that upper FET is zapped. It would be a very unusual failure mode but the reading seems to suggest it. It would give the overall voltage readings you are seeing with the fault.
I would replace that one FET making sure it is properly attached to the heatsink (but do not overtighten them though).
Old 15th October 2021, 07:34 AM   #11003
Loudthud is offline Loudthud  United States
Loudthud's Avatar
Perhaps others will chime in ... back in the late 80's I worked at a place that used lots of the IRF hexfets. They almost always failed as dead shorts. I cut a couple of TO-3s open and all you would see is a small black spot somewhere on the top of the die. I suspect Q3, the NPN ZTX450 or C2 the 1000uF cap.
Old 15th October 2021, 08:57 AM   #11004
Mooly's Avatar
Amp Camp Amp - ACA
If it has just failed G to S then I think that would be unusual tbh. Q3 and C2 were my first thoughts but they have been eliminated.
Originally Posted by captain pugwash View Post
Just checked C2 and Q3, all ok.
Old 15th October 2021, 03:19 PM   #11005
Sounds like a plan, thought I had some spares but don't, need to order pronto.
Old 15th October 2021, 06:27 PM   #11006
Mooly's Avatar
Amp Camp Amp - ACA
lets hope that does the trick.
Old 20th October 2021, 09:22 PM   #11007
Plott is offline Plott  Austria
Have to find one :)
Plott's Avatar
Amp Camp Amp - ACA
just a short question. As I don't like notebook-type PSU-s (they don't look good ... yes, the eyes are listening too), but I'm very satisfied with the 24v MeanWell SMPS, I thought I take an internal type and mount it into a chassis, suitable to ACA. My choise (MEAN WELL RS-100-24 Switching Power Supply SMPS 100W 24V 4.5A) has only 4,5A instead of 5A of the original - would it be enough?
Thank you in advance.
Istvan
DIY-gear: 2x ACA bridged, Frugal Horn Mk.III, XRK FAST TL
Old 20th October 2021, 09:31 PM   #11008
tyerkey is offline tyerkey
Location: Axtel KY. If you can find me you are welcome to visit.
Anchient thread. Problems were solved long ago.
Old 20th October 2021, 09:45 PM   #11009
Have to find one :)
Plott's Avatar
Amp Camp Amp - ACA
What do you mean? Ancient thread?
Istvan
Old 20th October 2021, 10:54 PM   #11010
6L6 is offline 6L6  United States
6L6's Avatar
Amp Camp Amp - ACA
Plott - yes, the 4.5A MeanWell will work perfectly.
Amp Camp Amp - ACAHide this!Advertise here!
Thread Tools
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 04:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 03:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 05:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 07:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
