Amp Camp Amp - ACA
Amp Camp Amp - ACA
Thread Tools
Old 13th October 2021, 09:18 PM   #10991
Plott is offline Plott  Austria
Have to find one :)
Plott's Avatar
Amp Camp Amp - ACA
Thank you - my bad, sorry. Switch down is the short-cut, the switch works "reversed".
Sorry for the confusion
Istvan
DIY-gear: 2x ACA bridged, Frugal Horn Mk.III, XRK FAST TL
Old 13th October 2021, 09:25 PM   #10992
ItsAllInMyHead is offline ItsAllInMyHead  United States
Amp Camp Amp - ACA
Ask me how I may have known that could be the cause of the confusion….
Glad it’s sorted.
If you want a friend, feed any animal - Perry Farrell
Old 13th October 2021, 09:28 PM   #10993
Have to find one :)
Plott's Avatar
Amp Camp Amp - ACA
Did you fall into this "trap" too?
I am ashamed...
Istvan
Old 13th October 2021, 09:31 PM   #10994
Amp Camp Amp - ACA
I sure did. That’s one of the reasons I did a full set of diagrams similar to the one I attached earlier. It took me far too long to work it out without a visual representation and showing the phase of the signal as it moved from input to speaker.
Old 13th October 2021, 09:34 PM   #10995
Have to find one :)
Plott's Avatar
Amp Camp Amp - ACA
Good idea Thanks for opening my eyes
The 30 years long brake from building audio equipment shows a clear effect
Istvan
Old 13th October 2021, 10:01 PM   #10996
6L6 is offline 6L6  United States
6L6's Avatar
Amp Camp Amp - ACA
Originally Posted by Plott View Post
So what is right?
Whoops!
The photo is incorrect, the panel instructions are correct. Speaker connections are different with self-bridged (RCA) vs XLR bridged. Sorry for the confusion, I’ll fix that.
Old 13th October 2021, 10:15 PM   #10997
Have to find one :)
Plott's Avatar
Amp Camp Amp - ACA
Thank you 6L6, this heals me somewhat
Istvan
Old 14th October 2021, 04:07 PM   #10998
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by Zen Mod View Post
if you're using non-leaded solder, think of using proper old school leaded solder
Agree with that. It seems that the solder has not fluxed nicely, it is grainy and that means that the contcts will be haphazard, maybe even changing contact during a warm-up and cool-down period.
I once bought a nice roll of silver solder in China, but it was one for factories for above 400 degrees, only fit for their fast very high temp soldering and special irons. It cost me my appetite for DIY for several years (everything I built broke down after some time...) and it was very bad for my temper.
Using such solder we only mess things up.
> Buy low temp solder. Low melting point, even under 300 degrees.
À la recherche d'un son perdu
Old 14th October 2021, 07:46 PM   #10999
captain pugwash is offline captain pugwash  United Kingdom
Noted.
As always plenty of people have chipped in with suggestions for my little problem and I am very grateful for that. My progress is painfully slow as I am scratching around for spare time at the moment so bear with me!
It is interesting that the help seems to fall into 3 basic categories;
1. Systematic measurement and fault finding.
2. Reflow all solder.
3. Remove and replace all transistors.
All of these approaches have their merits for me but I would like to get to the bottom of what went wrong.
Old 14th October 2021, 07:58 PM   #11000
Mooly's Avatar
Amp Camp Amp - ACA
I am a great believer in measurement
Can you do one quick check (if not already done) and that is with the amp OFF can you measure the resistance between G and S of Q2. Try it with your meter leads both ways around.
Does it read very low? Use a low ohms range and not the diode check range.
Amp Camp Amp - ACAHide this!Advertise here!
Thread Tools
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 04:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 03:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 05:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 07:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
