F5X -- the EUVL Approach - The Build Thread
F5X -- the EUVL Approach - The Build Thread Please consider donating to help us continue to serve you.
Old 2nd October 2016, 08:48 PM   #1001
samoloko is offline samoloko  Bulgaria
Originally Posted by alazira View Post
Can anyone tell me the spacing for the diodes on the heatsink?
After discovering the quasimodo thread I am looking to snub the transformers as well as replacing the diodes. Pre-building the bridges (PTP) would reduce the time the amp is out of commission. Anyone snub the primrose tx with the quasimodo?
which diodes you plan to use - FFPF30, HexFreds or else
Old 4th October 2016, 09:12 PM   #1002
alazira is offline alazira  United States
alazira's Avatar
This one: STTH15S12
Old 5th October 2016, 02:31 PM   #1003
thank you for reply
please tell us Impression after change
one thing that I remember from Mark posts Is that super fast switching diodes not always guarantee better sound
did you notice relatively high voltage drop - 1.9 V
Old 5th October 2016, 09:34 PM   #1004
Markus is offline Markus  Germany
Default Transformer Integration
When I was searching in this thread for a nice solution on how to integrate the power transformers and how to solve the transformer connectivity mess I saw that I was not the only one who was on the search for proper solution.
For those how might be interested this the solution I ended up with.
Since I know this question will come:
I have 12 V and 3 V secondary coils such that I can combine them to 9, 12 and 15V. The shown configuration privides 15V each.
Markus
Old 5th October 2016, 10:05 PM   #1005
pchw is offline pchw  United States
One important point to add, the number of amps drawn is limited by the lesser of the 2 windings.
- Fred -
Old 6th October 2016, 06:55 AM   #1006
EUVL is offline EUVL  Europe
Nice solution Markus.
Patrick
xen-audio.com
Old 6th October 2016, 03:01 PM   #1007
pmchoong is offline pmchoong  Malaysia
pmchoong's Avatar
Hi Markus, what are those white pieces of flat plates on the transformers?
Old 6th October 2016, 07:50 PM   #1008
Hi Pmchoong,
the white pieces are flanges made from plastics, more precisely from POM (PolyOxyMethylen). The flanges are sitting on the potting material the center holes of the toroids are filled up with. On the bottom side the transformers are sitting on support rings that are also interfacing to the potting material. The coil itself is free from any mechanical contact and related mouning stress, only the potting material experieces the monting stress.
I attached the sketches of both parts.
Cheers
Markus
Old 6th October 2016, 08:01 PM   #1009
Perhaps you should also educate us why it is important to have the coil winding stress free.
Patrick
xen-audio.com
Old 6th October 2016, 08:09 PM   #1010
alazira's Avatar
thank you for reply
Yeah, I noticed the large Vf, so I may need to adjust the zener ref. Thankfully I used sockets for those so no big deal to change them. It also has a Softness=2, although with the snubbing not as much of a factor. More importantly, in listening tests (DAC power supply) I preferred it over previous favorites.
I will report the snubber values I find with the quasimodo here, although I'm not sure when that will be (sometimes these projects sit around for months before I get to them).
F5X -- the EUVL Approach - The Build ThreadHide this!Advertise here!
F5X -- the EUVL Approach EUVL Pass Labs 889 31st December 2019 11:50 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 04:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 07:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 05:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 05:49 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
