F5 Turbo Builders Thread
Old 2nd March 2020, 02:59 PM   #5941
BigE is offline BigE  Canada
BigE's Avatar
Originally Posted by Zen Mod View Post
nope
if we are thinking about same cap
Thanks Zen Mod!
That would be C3/C4 with value around 1nF.
I will add it to the boards before continuing.
( Need to complete some other work tonight, then back the F5T -- I did a massive rewiring job on it.... for the better???? we'll see. ).
Old 3rd March 2020, 06:43 PM   #5942
takitaj is offline takitaj  United States
BigE, there's probably no need but I put 1nf into all 4 boards (C3/C4). I did it as extra insurance against oscillation. (I sleep better) One nf or two isn't going to reduce the bandwidth any appreciable amount. Sleep is important!
TJ
Old 10th March 2020, 02:28 PM   #5943
BigE's Avatar
TJ
I shall do this shortly. At the moment, I am embroiled with getting an active speaker system equalized -- and adding a tweeter. It's a bit slow going.
As you wrote earlier: I wouldn't worry too much about the 100R from emitter to drain either, unless you find you have an oscillation issue and it can't be resolved by increasing C3 & C4 or increasing output gate stoppers.
Right now, they are the standard 47.5 ohm. What value would you suggest? Would adding a very small inductor help to block the oscillatory frequencies?
When I fire this up next, I will take a look at the outputs on a scope to ensure that there actually is *some* oscillation. I should be able to see something. Recall, oscillation is suspected because the biasing output offset is very different with and without shorting plugs in place. ( Some 300 mV ).
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
