F5 Turbo Builders Thread
Old 5th October 2019, 05:21 PM   #5781
thompsontechs is offline thompsontechs
Originally Posted by AudioSan View Post
Any TO-220 NPN and PNP with the correct pin out can be used.
DO we need to do any matching on these? hFE maybe?
JT
Old 5th October 2019, 05:58 PM   #5782
AudioSan is online now AudioSan  Norway
i have not testet. But as far as i remember, there was no matching of this devices.
Old 6th October 2019, 01:40 AM   #5783
takitaj is offline takitaj  United States
No matching of the cascodes is needed.
I wouldn't worry too much about the 100R from emitter to drain either, unless you find you have an oscillation issue and it can't be resolved by increasing C3 & C4 or increasing output gate stoppers. If you do decide to add them in then you'll have to cut traces.
I would recommend to spend a little extra $ and get .1% or .01% source resistors (inputs and outputs) - or - if you have an accurate enough bench dvm then match them.
TJ
Old 7th October 2019, 06:50 PM   #5784
BigE is offline BigE  Canada
BigE's Avatar
TJ
Hi Takitaj,
Either cut traces or add lands for the new resistor and connection from emitter to drain I suppose. I hate cutting traces, but in this case it's probably easiest.
Does a large difference in DC offset when biasing with/without shorted RCA jacks indicate presence of oscillation?
Would oscillation be visible on scope directly from the speaker outputs?
What value of Gate stoppers or C3/C4 would you use if you detected oscillation?
Old 7th October 2019, 07:19 PM   #5785
nashbap is offline nashbap  United States
If you do decide to add them in then you'll have to cut traces.IJ
No need to do that. Bend the relevant leg of the cascode transistor up 180 degrees, now solder one leg of the resistor to it and insert the other resistor leg into the PCB hole.
nash
F5TV3, AVC, BA3b pre, Salas DCG3b, OBL-15, SonyVfet2pair monos
Old 7th October 2019, 07:33 PM   #5786
JeffYoung is online now JeffYoung  Ireland
JeffYoung's Avatar
Everyone should build at least one really simple dead-bug circuit. It'll give you a whole new perspective.
Manhattan and Pittsburgh Electronics Prototyping Techniques — Parallax Forums
Old 7th October 2019, 08:53 PM   #5787
BigE's Avatar
nash
This also gives a good test point for measuring if the cascode is working.
Old 7th October 2019, 10:21 PM   #5788
Originally Posted by BigE View Post
Hi Takitaj,
As mentioned you can bend a lead up (cascode emitter or JFET drain) and solder one end in the hole and solder the other end to the lifted leg or lift both and solder it across there. To each his own.
When I tried it I cut the traces on the top of the board, scraped some extra back for a place to solder to and used a 1/4w Dale. The tiny blue ones that are the size of other 1/8 watters. I didn't have an issue, I did it "just in case" but it seemed like it lost some sensitivity so I built a new FE board without it. The F5T v3 requires 2 sets of output boards and only one FE per channel so I already had the second set.
I wouldn't think a DC offset at the output would indicate an oscillation. Sounds more like a bias setting issue. When you set the bias you will most likely find the N channel and P channels won't match when the offset is at zero, it's ok and is expected. Just make sure the highest channel is where you want it (~350mv) and offset is as close to zero as you can get it when hot. Different ambient air temps will affect the bias and consequentially can affect the offset. You'll probably also see a big range of offset from cold to fully warmed up. I've seen as much as 200mv at turn on, cold, and it will settle back to near zero when fully warmed up. Even when the output devices are well matched. Most match them at some certain voltage/current/temp. While they are out of that range they can differ a lot and is why curve trace matching is the ultimate. What's important is the offset is set to near zero when bias is set and amp is fully hot. You should short the input when setting bias and offset.
If there is an oscillation you 'should' be able to see it on the scope. May show up as a thick fuzzy trace instead of a nice crisp line. Ie: high frequency (MHz?) signal riding on the audio signal.
I believe 6L6 had mentioned up to 680R. I personally increased them to 100R instead of 47R. Again, not that I had an issue, it was Just in case.
TJ
Old 7th October 2019, 11:32 PM   #5789
Sorry, missed one.. C3 & C4 I used 1nf in all 4 positions. I believe that's what Nelson recommended in the F5T manual. He also mentions the same across feedback resistors R7,8 and R9,10. I didn't go that far, didn't need to.
TJ
Old 8th October 2019, 02:09 PM   #5790
BigE's Avatar
Thanks for all the help!
The issue I had last time I tried to bias was that with input shorted, I got a certain offset. Without input shorted, I got a vastly different offset. Memory fails for an exact number.
The amp had been fully warmed up.
I am going to try to complete the amp shortly, so will keep an eye on this again.
I'll look at adding caps on the feedback as well.
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2019 diyAudio
