F5 Turbo Builders Thread
Old 4th September 2019, 01:00 PM   #5711
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Nice casework!
Still, I'd have been tempted to use the 308 valve cover in the background...
Old 4th September 2019, 07:13 PM   #5712
elwood625 is offline elwood625  United States
elwood625's Avatar
Those are the valve covers on the "wall of dead" engines. I thought about using the 308 and the Maserati 4AC twin turbo as they are close to the same physical size. Someday..
ACA v1.6 monoblocks, Balanced Zen Line Stage, M2x, B1 Korg triode, 12AX7a Phono amplifier, Balanced B1 Korg triode, 6FG6 "Magic Eye" tube VU meter
Old 10th September 2019, 05:36 PM   #5713
rhthatcher is offline rhthatcher  United States
Built and tested 2 PSUs for a pair of V3 Monos. I used temporary 0R47 resistors to test, chokes will go in the amp chassis.
Chassis and amp boards will come next. Also need to do some mosfet matching.
File Type: jpg CCA7E4FF-7EA4-4437-A20A-C78092636671.jpg (863.1 KB, 161 views)
File Type: jpg C5A2C7F1-B9BB-4C6A-AA48-7A26AD6CA88A.jpg (749.4 KB, 156 views)
Old 10th September 2019, 08:15 PM   #5714
AudioSan is offline AudioSan  Norway
I belive that is bleeder resistors you have soldered. they need to be around 2.2Kohm 5W.
Old 10th September 2019, 08:30 PM   #5715
AudioSan - The bleeders are 2K2 3W. Same as I have used in Aleph J and standard F5.
Old 10th September 2019, 09:39 PM   #5716
I saw it now i thought that was the 0.47ohm resistors you were talking about.
Old Yesterday, 03:24 PM   #5717
thompsontechs is offline thompsontechs
Hello guys/ladies. I'm building a 2 channel F5T V2 with the V# boards. I've been sourcing parts and have a quick question for you...
Both the FQA12P20 and N20 are now obsolete, I search the forum and found several people who have used other packages.
Would these be suitable? Some of the values on the Datasheet look good others, are what brought me here to ask those with more knowledge.
Q3-4 IRFP9240PBF
Q5-6 IRFP240PBF
Thanks guys, I do appreciate your time.
JT
Old Yesterday, 04:15 PM   #5718
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Many have successfully used IRFP240/IRFP9240 in their F5/F5 turbo builds.
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old Yesterday, 07:45 PM   #5719
Thanks Dennis
Old Today, 05:24 PM   #5720
Do Fets Q3-4 5-6 need to be matched pairs N-N and P-P?
I got all the parts in today and I'm getting ready to build!!
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2019 diyAudio
