F5 Turbo Builders Thread
Old Yesterday, 02:41 AM   #5531
BigE is offline BigE  Canada
BigE's Avatar
Originally Posted by 6L6 View Post
If your PSU works and has a stable ground, you donít have your transformer attached in the manner shown on the schematic you posted in #5526.
Which leads to the question, how DO you have it attached, with the 5 secondaries...??
Just like the diagram shows. .
One V+/CT/V- secondary is not used. The 4 other secondaries are split into two groups and run in parallel. There is one full wave rectifier per channel.
The caps are strapped together on the PCB boards. They are the white teabag boards. There is a pair of boards per channel.
The ground on the right hand side of cap bank as shown on the diagram goes to the ground connected to the diode bridge/CL-60. There is one diode/CL-60 per channel.
Both of the diode/CL-60 grounds are connected to the same earth point on the chassis where the safety earth comes into the box.
I hope the drawing is OK.
Old Yesterday, 02:59 AM   #5532
wwwtttwww is offline wwwtttwww  Canada
drawing is not ok to see it clearly. it is tough to see how you hooked them up.
i would feel there could be something wrong but can not indicate it.
Old Yesterday, 03:17 AM   #5533
BigE's Avatar
The secondaries are in parallel with the other secondaries. If they were not, fuses would be blowing.
The connection between the center tap and the zero volt line on the left of the cap bank is not made.
The ground on the right of the cap bank is connected directly to the ground on the left on the diode/CL-60. The other side of the diode/CL-60 is connected to earth.
This shows only secondary side and ground.
Old Yesterday, 03:18 AM   #5534
6L6 is offline 6L6  United States
6L6's Avatar
Photos please
Old Yesterday, 03:35 AM   #5535
BigE's Avatar
does the re-drawing help? The build is a mess.... The first photo shows a terminal strip. With secondaries attached. The unused ones have heatshrink wrapped ends. The flying caps/resistors are snubbers.
One pair of red/white goes to a cap bank for each channel. The second is a closeup of one of the cap banks. You can clearly see that red and grey are +/-. No CT connection on the diode bridge side.
There are a lot of relays around the boards. The notion was that in the event of a short cycle while powering up, a relay would disconnect the diode bridge from the cap bank, to enable the thermistors to cool.
But this is not about the relays. This is about parallel secondaries of a CT transformer, still supplying the correct voltage, even though the CT is disconnected.
The secondaries are 2xV apart. The zero volt line is connected at the signal ground only. That gives the center voltage reference. Then V+ is V above signal ground ,and V- is V below. The signal ground is 10R above earth due to the CL-60.
So there is a center reference.
Old Yesterday, 04:35 AM   #5536
BigE's Avatar
Well, I decided to trust my meters, and the new channel biased up BEAUTIFULLY. Unfortunately, noisy.... 1.25mV ( channel with meters attached ) and 0.775 mV rms, according to the entry level Digital scope.
Now, onto grounding schemes....
Although I may have little luck with two channels and multiple secondaries in one box.
Also, this is with the output boards wired in parallel, which will certainly increase loop area.
Thanks for all the help!
I've got to go learn a bunch of stuff now.
Old Yesterday, 02:55 PM   #5537
BigE's Avatar
RE: grounding the center tap.
I found this online. EEVBlog entry
This mainly depends on the transformer and only after that comes if you like supplies with grounded outputs. If you let it float the transformer needs to be rated for use in class II appliances (double / reinforced insulation). You'll find that information sometimes on the nameplate of the transformer or you can see that it's a doubly insulated transformer (separate coil chambers, insulation to core etc.). If unsure, ground it.
Old Yesterday, 03:27 PM   #5538
BigE's Avatar
Originally Posted by Bfpca View Post
If you are looking for more matches to the ones you got from me then I have more that are close to the same VGS values.
Thanks! Maybe next payday...
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2019 diyAudio
