F5 Turbo Builders Thread
Old 15th April 2019, 01:27 PM   #5491
BigE is online now BigE  Canada
BigE's Avatar
I've read about a third or so. It's not so bad, but then again, I don't know this stuff..... There are some questions coming up, but maybe finishing it will answer them.
For sure, you need to know how the circuit was implemented so that the HBR resistor can be inserted in the right place.
Old 15th April 2019, 02:32 PM   #5492
BigE's Avatar
Are the humbreaking resistors supposed to be inserted between the junction of R3/R4 and the audio signal ground?
Old 15th April 2019, 05:26 PM   #5493
Itsmee is online now Itsmee  England
Itsmee's Avatar
Page 56 of http://hifisonix.com/wordpress/wp-co...ound-Loops.pdf should answer your question, the lowest bridge & cap in the bottom right corner are replaced with a CL60 in the FW designs.
Old 15th April 2019, 07:16 PM   #5494
BigE's Avatar
Thanks Itsmee. Pages 36 and 37 are more detailed. I think 56 assumes that the amps are on a single PC board, while the F5T is spread over a couple.
My question is where on the FE board to attach the HBR.
Is it just at the GND point or is the GND point on the FE board on the wrong side of the feedback resistors ? ( I am at the office, so cannot check )
Old 15th April 2019, 07:41 PM   #5495
Itsmee's Avatar
Originally Posted by BigE View Post
...My question is where on the FE board to attach the HBR...
You don't, it's in the PSU between 0V and chassis earth, unless your talking about low value resistors (10R ish) in the ground connection between the input socket and ground on the PCB; only do that if you have hum problems you can't cure any other way.
Old 15th April 2019, 07:55 PM   #5496
BigE's Avatar
Hi Itsmee,
I have the diode bridge and CL60 in place already.
There is hum I'd like to get rid of, but before installing the HBR though, there are quite a few other things to implement -- proper wiring being one of them -- like a proper star ground or 'T'.
My main issue is space in the amp. I built the case to fit a stand, and that meant I had to either mount the transformer on the face plate, or mount the cap banks on the face plate. I chose the cap banks, since then the diode bridges had easy heat sinking. But that put the transformer in the middle of the amp.
I'm going to measure the noise with a QA400 as I go, to test for any changes.
Old 15th April 2019, 09:10 PM   #5497
Itsmee's Avatar
Adding the 10R's may not help, thats for breaking hum loops, if it does, rewire.
Your problem may be induced hum from local proximity, first move the wiring, then try rotating the transformer, next try standing it vertically - it moves the flux lines by 90°, try both N-S & E-W 'doughnut hole' orientation to see which gives the least hum; decide from there what needs to be done.
Old 15th April 2019, 11:26 PM   #5498
BigE's Avatar
It looks to me like the FE board needs to be modified for the HBR to be installed as per the Hiphonics article. Specfically, the article shows that the RCA shield is connected to the HBR on it's way to the zero volt line, as does the ground between R3 and R4 ( I think ).
A picture says a thousand words.... attached is how I think the HBR should be added. The diagonal line is the HBR, the thick ground is cut, and the link and group of G's are connected. It is labelled with black text.
BEWARE: I'm not an expert. Just trying to learn something. It's easy enough to operate as designed.... just replace the HBR with a jumper.
Does that look right?
Old 16th April 2019, 12:30 AM   #5499
Itsmee's Avatar
Can't help with the PCB, I dont know it - haven't built one with those boards.
There are lots of sucessful builds without the HBR.
Pictures of your build would help.
Old 16th April 2019, 01:21 AM   #5500
BigE's Avatar
Right now, I am working at cleaning up the power supply... again. I used a bunch of crimped push on connectors, and a nice tool, but it was just as powerful as a set of pliers.. So, I am soldering them all on, and heatshrinking after.
Four literally fell off the wires. I am amazed it was working.
I will be posting some shots once it's working again. And I do want to measure it again... I did 6 years ago, but I am a bit more cautious/scared these days.... I am slowly learning how little I know.
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2019 diyAudio
