F5 Turbo Builders Thread
Old 13th February 2019, 01:50 PM   #5371
BigE is offline BigE  Canada
BigE's Avatar
What brand of source resistors are most people using for their builds? I used MPC74 last time, and need more. I'm not keen on their construction.
Has anyone tried Non-inductive wire-wound? Any suggestions?
Thanks!
Old 13th February 2019, 02:03 PM   #5372
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
There is not such a thing as non inductive wirewound. Maybe less than other but that is all.
I recommend Mills only.
Old 13th February 2019, 03:43 PM   #5373
Blitz is offline Blitz  Germany
Well... there are many good sounding ww, tyco er-series as an example like er74 etc. Mills are very vibrant, bright, a bit technical... and there are many different versions.. ns, rs, grey, brown enamel...
Old 13th February 2019, 05:22 PM   #5374
Bfpca is offline Bfpca  Canada
I used what Mr Pass had specified. The way I look at it Pass amps are pretty much the top tier for sound quality and if Mr Pass recommends parts then they will sound fine. We are all free to experiment, of course, but I just don’t have the time or funds to experiment with resistor types and simply use what is recommended by the designer.
Old 13th February 2019, 06:03 PM   #5375
Itsmee is offline Itsmee  England
Itsmee's Avatar
Panasonic ERX are nice
Old 13th February 2019, 06:30 PM   #5376
6L6 is online now 6L6  United States
6L6's Avatar
If his amplifier is quiet when the inputs are shorted, it’s a ground loop, not anything to do with resistor brand.
Old 13th February 2019, 07:20 PM   #5377
TheNuge is offline TheNuge  Germany
Originally Posted by 6L6 View Post
Please pose some in-focus, well-lit photos, particularly of the wiring.
was away for work, but here goes!
BTW., I just realized that I posted in the Turbo thread, but have actually built regular F5s.... should I move the posting or re-post elsewhere?
Here's a pic of amp #1:
On Amp #2 I tried attaching the speaker negative wires directly to the PSU ground. The function ground is de-coupled from chassis ground with a CL-60 thermistor.
Should I try making a true star-ground, where all the negatives "feed off" from?
Cheers
Es
Old 13th February 2019, 07:28 PM   #5378
Itsmee's Avatar
The earth wire on the transformer bolt - have you created a 'shorted turn' or is that an electrostatic screen?
Old 13th February 2019, 07:35 PM   #5379
Itsmee's Avatar
...not anything to do with resistor brand.
Maybe i should have quoted
Originally Posted by BigE View Post
...I used MPC74 last time, and need more. I'm not keen on their construction... ...Any suggestions?
Old 13th February 2019, 08:19 PM   #5380
It's a screen - at least I think so...
Cheers
Es
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2019 diyAudio
