F5 Turbo Builders Thread
Old 20th June 2018, 04:50 AM   #5171
Hikari1 is offline Hikari1  United States
So...I replaced the jfets with another batch. Offset is 0mv when inputs shorted and 50mv when not shorted. Is this acceptable and normal?
Old 20th June 2018, 04:52 AM   #5172
6L6 is offline 6L6  United States
6L6's Avatar
Yes.
Old 26th September 2018, 12:46 PM   #5173
VonLoon is offline VonLoon
Default balanced input?
So first off thanks to all you dedicated members who have kept this community going for lurkers like me. I'm having trouble finding information that has certainly been discussed. I have a a 'fully balanced' DAC and preamp, going single ending means either using only half the digital hardware or adding a device to sum the signal.
What i really want a proper balanced input, is this feasible with F5T as 50W stereo (not 2 kit mono block) I know ba-1 and m2x are also options, also could start with an SE amp and change it up latter, same chassis and much of the same PS.
I'm still in the research and soldering practice phase, but i feel i need to buy before boards or matched fets run out.
Old 27th September 2018, 09:21 AM   #5174
huh, cant add to old posts.
I'm pretty bad at reading schematics, but it seams like using this front end balanced should be as easy as connecting the 'extra' input to link. q1 and q2 feel the voltage difference between input and link through r3 or r4.
If I got this right I'm probably just going by the boards and go for it. Last amp project was and Altoids tin ear bud amp a few years back. Picked up an old CRT tv from by a dumpster and removed then re-soldered most of the input board for practice. Feeling pretty good.
Old 27th September 2018, 09:55 AM   #5175
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
try illustrating that with schematic
I'm not following you this way
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 27th September 2018, 10:29 AM   #5176
In L6L's build guide he mentions that the link hole was useful for balanced builds but everyone else must connect it to the neighboring ground through hole. I'm wondering if anyone has published proper use of this 'link', I wasn't sure if it was for accepting a balanced input or connecting to a balanced output stage.
F5Turbo Illustrated Build Guide
Old 27th September 2018, 11:07 AM   #5177
Zen Mod's Avatar
nope , that remark is for possible bridging of two F5 channels , for establishment of SUSY operation
you can't connect balanced signal to regular F5 channel , without resorting to using some external gizmo - either xformer of active circuit
Old 27th September 2018, 05:24 PM   #5178
gasgeek is offline gasgeek  United States
Anyone, I built a pair of balanced F5 turbo's now I'm ready for a balanced preamp project to match. Any suggestions?
Old 27th September 2018, 05:33 PM   #5179
hmm.. I just realized that I have in my possession a X2 service manual schematic. maybe i will go that way.
Old 27th September 2018, 05:46 PM   #5180
UGS-UP-Mini: A 25W SUSY Amp
Use just the front end.
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 07:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 07:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 08:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2019 diyAudio
