Building a Pearl 2
Building a Pearl 2
Thread Tools
Old 26th September 2021, 06:08 PM   #2821
6L6 is offline 6L6  United States
6L6's Avatar
Building a Pearl 2
Almost any produced in the last 5 years or so, as “super bright” is becoming more and more common. That’s almost certainly what you have in yours, considering your comment about them being like headlights. All you need to do is make the LED resistor more ohms your tame that down.
Old 26th September 2021, 06:25 PM   #2822
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
Building a Pearl 2
For front panel "pilot light" applications, I prefer LEDs with the widest possible viewing angle -- which is a manufacturer guaranteed specification on many datasheets. The wider the viewing angle, the greater the likelihood that you'll be able to see whether the LED is on or off, at all positions in the listening room. Not just dead center. Here are a couple example LEDs that specify a quite wide, 120 degree (!!) viewing angle:
3MMLED-GREEN: Jameco Valuepro : LED Super Bright Green Diffused 3mm (T-1) 520nm 5000mcd : Opto & Illumination
3MMLED-BLUE: Jameco Valuepro : LED Super Bright Blue Diffused 3mm (T-1) 465nm 5000mcd : Opto & Illumination
Old 26th September 2021, 11:22 PM   #2823
aalewis is offline aalewis  Australia
Thanks for the replies
Old 20th October 2021, 03:34 AM   #2824
Anticipation is offline Anticipation  New Zealand
Wow, what a fun journey this has been! The Pearl 2 is an amazing piece of kit. I just wish I had found this thread sooner, it would have saved me a lot of pain chasing RF (thanks to C7) and trying to balance the output. Almost there now, thanks to the input from all you awesome people. At the tweaking stage now: R14 for gain, and playing with R8 to get the voltage more in line with the ideal around Q3. Have ordered some 20R resistors. Added another 100nF under the board to lower the cut-off. I have fitted 6,800uF caps rather than the specified 10,000uF, as they're shorter, meaning I could fit it all in a low-profile 1U high case. Yes, PSU as well!! and it's as quiet as I've ever heard a phono preamp. Not a hint of hum, even with the volume cranked right up
Old 27th October 2021, 04:21 PM   #2825
rhthatcher is offline rhthatcher  United States
Building a Pearl 2
I'm getting parts ordered for my build. This project is in a queue of many, so I don't expect to build until sometime in the middle of winter. I need to order the chassis, too.
One thing I'm going to play with is the capacitor and resistor loading using rotary switches. My buddy's EAR phono has something like this, so I thought I'd build on that concept. I sent these boards off for fab last night, and the switches are inbound, too. I'll report back on how they work out. If anyone wants to beta test, I'll have extra boards.
The idea is one switch for caps on a DP6T switch with 5 cap values plus leaving one open for no cap loading.
Resistor loading will be one 16 position switch per channel. All resistors are parallel to the 47k5 on the main board. 15 resistors on the switch + one open position for 47k5 loading.
Old 27th October 2021, 05:52 PM   #2826
diyAudio Donor
Building a Pearl 2
I lost a battle against obsessive compulsive disorder this morning.
_
Old 27th October 2021, 07:08 PM   #2827
Building a Pearl 2
Mark - nice catch! I wasn't thinking to do that at 1AM when I finished... It's easy (and cheap) to throw a few more boards into an existing order, so I added those traces. And while I was at it I made a new wider version with updated resistor footprints. So I'll have vertical and horizontal resistor PCB's to see which I like better...
Old 27th October 2021, 08:13 PM   #2828
Dennis Hui is online now Dennis Hui  Canada
Hoopy Frood
Building a Pearl 2
This is very nice and looks to be a great addition to the Pearl 2.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 27th October 2021, 09:24 PM   #2829
McQuaide is offline McQuaide  United States
I did this with 5 position rotary switches, and added another one to control gain via R14 to select between 300, 600, and 1K ohms.
Mark Micro Seiki DDX-1000>Pearl 2>BA-3 FE>F5>Mirage OM-7 Towers
Old 27th October 2021, 09:35 PM   #2830
Building a Pearl 2
I'm planning to do a switch for Hi/Lo gain. In reality, it will run on high gain nearly all the time with an MC cart. It may get a little run time with an old beater 'table with a MM - so I'll put the switch in for that case.
Building a Pearl 2Hide this!Advertise here!
Thread Tools
RIAA caps for Pearl and Pearl 2 AudioLapDance Pass Labs 7 22nd May 2015 08:19 PM
pearl HELP! d to the g Pass Labs 24 31st May 2007 02:56 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 04:16 PM
Anyone building a pearl phono soon? mattjk Pass Labs 8 24th March 2005 01:20 AM
The Pearl-X Vince Maida Pass Labs 12 28th July 2002 08:28 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
