Building a Pearl 2
Building a Pearl 2
Old 4th February 2020, 03:13 AM   #1711
metalman is offline metalman  Canada
metalman's Avatar
I put in sockets for R15 and C15 for making gain adjustments, and I left R14 at 1K and R16 at 100K. With R15 shorted and a 46.4K resistor inserted at C15 the gain is down by 10dB to 45dB at 1kHz. You could get the same effect by leaving everything else unchanged and increasing R14 to 3.2K.
Terry
Darn career gets in the way of my audio addiction!
Old 4th February 2020, 04:01 AM   #1712
WBS is offline WBS  United States
Building a Pearl 2
Thanks Terry! I'm happy to hear it's as simple as increasing the value of just one resistor. I'll order a handful of resistors so I can closely match them.
"Only those questions that are in principle undecidable, we can decide." - Heinz von Foerster
Ethics and Second Order Cybernetics
Old 10th February 2020, 03:55 AM   #1713
gigigirl is online now gigigirl
Hi, WBS, Sorry for the late reply. Had to open up my Pearl. Unfortunately for me my MC is 300 ohms, H/O MC is 600 & MM 1000, so it looks like a SUT is required.
Yes SLS, I realise that, however occasionally I forget to turn the V/C down when I switch over to CD and the older I get the more forgetful I am getting. (nearly time for the retirement secure hospital wing!!!)
Cheers
Old 10th February 2020, 05:40 AM   #1714
Building a Pearl 2
Thanks for the response Gigigirl! Today I swapped out R14 raising it from 1K to 3.2K as metalman suggested. I matched them for to insure good balance between channels.
Metalman, I appreciate your recommending which value to use. What previously was 6:30 to 7 o'clock on my volume pots is now around 9 o'clock. High volume is now 12 to 2 o'clock. It sounds noticeably better to me.
It was more difficult than I imagined it would be. But thankfully I didn't ruin the pcb!
Old 13th February 2020, 12:01 AM   #1715
codyt is offline codyt  United States
codyt's Avatar
Wrapped up my Pearl 2 boards this evening. PSU is also ready - just waiting on chassis’ to arrive from Modushop. Pretty straightforward build so far. My goal was to get the RIAA boards in a 1U chassis, so that drove some of the component choices.
For the 6.81k resistor just before the RIAA portion, I used a couple Shinkoh resistors that measured in at 6.78k. Anybody see a potential problem in that 300R drop?
File Type: jpeg EA074173-7C01-4A66-B980-4758424E9953.jpeg (133.6 KB, 224 views)
File Type: jpeg 06EB2211-29D4-414F-B8B3-E9887355E0EF.jpeg (82.6 KB, 212 views)
Old 13th February 2020, 12:50 AM   #1716
6L6 is offline 6L6  United States
6L6's Avatar
Building a Pearl 2
Close enough.
Old 14th February 2020, 02:02 AM   #1717
Dadbeh is offline Dadbeh  United States
Dadbeh's Avatar
Originally Posted by cubicincher View Post
Hello members,
I use exactly the same bridge-rectifier together with a CL-60 thermistor for
building my ground-loop-breakers.
I use them in all of my DIY- Pass-poweramps.
Sometimes I did it with 2 single Diodes (direction against each other - paralleled together with a paralleled resistor around 10 Ohms) in my preamps, active crossovers,... with lower power consumption.
Works beautiful. Also in Germany with 230V/50Hz.
But hum or hiss can also have other reasons!
But often there are groundloops. My experience.
Greets
Dirk
what does CL-60 mean? i am about to complete an order for a few parts and im inclusing the ones for the ground loop breaker and the last parts that im not sure about which speciufications to buy is the thermistor.
im getting this rectifier: GBPC3510 ON Semiconductor / Fairchild | Mouser
Old 14th February 2020, 02:47 AM   #1718
6L6's Avatar
Building a Pearl 2
CL-60 Amphenol Advanced Sensors | Mouser
Old 14th February 2020, 05:07 AM   #1719
dewdrop is offline dewdrop  Singapore
If not, get shorter brass standoffs.
Old 20th February 2020, 08:53 PM   #1720
Qwin is offline Qwin  United Kingdom
Qwin's Avatar
What size are the RIAA PCB's?
This was asked at Post #10 but no answer was given as far as I can see. Spent a couple of hours looking for this info as its not on the passdiy.com pages.
Building a Pearl 2Hide this!Advertise here!
RIAA caps for Pearl and Pearl 2 AudioLapDance Pass Labs 7 22nd May 2015 08:19 PM
pearl HELP! d to the g Pass Labs 24 31st May 2007 02:56 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 04:16 PM
Anyone building a pearl phono soon? mattjk Pass Labs 8 24th March 2005 01:20 AM
The Pearl-X Vince Maida Pass Labs 12 28th July 2002 08:28 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
