L'Amp: A simple SIT Amp
Old 6th October 2019, 09:35 PM   #3071
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
L'Amp PSU sneak peek.
Do you even star ground, bro?
Gravity - Making the G since 13.7 billion B.C.
Old 7th October 2019, 12:39 PM   #3072
plasnu is online now plasnu  United States
Star ground has any advantage here? I was told series ground is better...
Old 7th October 2019, 01:15 PM   #3073
hates ground loops
Rodeodave's Avatar
Advantage...hm. I believe that with the given architecture - involving screw terminal caps, point-to-point wiring, voltage regulators and significant distances between building blocks - it is actually easier to implement star grounding. And with quiescent currents of up to 3A, I'd rather have a separate current return path for each PSU cap.
Almost done
Old 7th October 2019, 03:24 PM   #3074
twitchie is offline twitchie  Canada
Magic Smoke Liberator
Looks so warm and cool at the same time!!! Great job @Rodeodave!
Old 7th October 2019, 09:53 PM   #3075
hates ground loops
Rodeodave's Avatar
Alright, I finished the amp tonight and fired it up. Biasing went without a hitch, no smoke, no drama. Or so I thought. After hooking up some headphones I discovered that there's an awful lot of hum/buzz present. The scope showed a similar picture.
I'm suspecting the ground layout really. Currently all grounds meet at the star ground. I think I'll try and have the signal grounds and the bias supply ground meet at the VFET, and route it to the star ground from there.
Once I get the amp working quietly I'll pull some numbers from the circuit and mess around with finding the sweet spot.
Old 7th October 2019, 10:07 PM   #3076
Rush is offline Rush  United States
Those light bulbs are awfully close to the V-Fets. Could they be inducing your hum/buzz?
Rush
Old 7th October 2019, 11:11 PM   #3077
res07njc is offline res07njc  United States
also, might be helpful to have two star grounds... main one for PSU at chassis, and another star as floating amp circuit(s) ground, connected to PSU ground with/series a CL-60 thermistor. The resistance of the thermistor helps block any loops.
Old 8th October 2019, 03:40 PM   #3078
hates ground loops
Rodeodave's Avatar
I did some light probing, and it looks like the output is mirroring whatever is coming out of the bias supply, and that ain't clean DC. At least I think I know where to start cleaning up.
Old 14th October 2019, 10:43 AM   #3079
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
All Stars are connected.
M.
https://youtu.be/tcXg9t24JFA
Old 14th October 2019, 08:40 PM   #3080
hates ground loops
Rodeodave's Avatar
I couldn't get the negative supply generator to work like intended, so I'm converting it to a proper negative bias supply with a dedicated transformer. I have this small-ish 12VA 40Vac (230V primary) transformer that I'll be running off the 44Vac secondary of the main transformer, which should give me something like 11Vac or about -14Vdc to work with. I have also found a cozy place for the little fella:
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 14th November 2011 11:41 PM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2019 diyAudio
