L'Amp: A simple SIT Amp
Old 9th July 2018, 08:31 PM   #2941
sontero is offline sontero  Italy
sontero's Avatar
Originally Posted by Michael Rothacher View Post
I wouldn't recommend the MoFo circuit for a SIT. Some other follower, perhaps. But If I had some 2SK180's lying around, I use them in a CS amp.
Ok not mofo scheme for sk180
which means "CS amp" Mr.Rothacher
I hate abbreviations.....
Ps: maybe I understood
does it mean common source?
Old 9th July 2018, 09:23 PM   #2942
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Common Source. Output taken from the Drain, has gain e.g. L'Amp.
Visit AudioMaker.Tech
Old 17th August 2018, 06:02 PM   #2943
plasnu is offline plasnu  United States
Hi MR,
Why would you not recommend MoFo SIT? I wonder if any technical reasons.
The prototype schematic of FW SIT-3 was CCS loaded common drain SIT, but NP has later replaced it with DEFiSIT.
I have tried choke loaded Sony VFT L'amp with both common source and common drain (MoFo like?), and I noticed the difference in sound signature between them, probably not only due to the obvious difference in damping factor.
Old 17th August 2018, 06:45 PM   #2944
AudioMaker.Tech
MoFo benefits greatly from the high Drain resistance of the MOSFET in terms of output impedance and noise.
The Sony SITs don't offer much in the transconductance department and you wind up needing some gain in the front just to get unity. That's not to say NP might not have other ideas. I'm sure he does.
Old 17th August 2018, 07:37 PM   #2945
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
One more question to Mr Rothacher please
Ok Sony Vfet's have too little gain but is doable MoFo Sit with higher transductance Tokin's
like 2SK180 or THF-51 and big 2.5A ~ 3.5A rated choke ? Kind regards
File Type: jpg 8B29EE65-D98D-4090-8096-F3AAB3FD3004.JPG (172.7 KB, 272 views)
File Type: jpg D5BE1740-2A70-4920-9E6C-4ACE240A5461.jpg (303.0 KB, 261 views)
File Type: jpg E547BC30-938A-45E7-906E-3D39F9720C0D.JPG (339.8 KB, 258 views)
File Type: jpg 766D2D81-8281-421E-9D4E-00A63BB91220.JPG (310.1 KB, 252 views)
class A amplifiers with full range speakers
sings like angels in heaven
Old 17th August 2018, 08:00 PM   #2946
AudioMaker.Tech
Not so much with the inductor load, IMO.
Try NP's original SIT-3 if you want a SIT follower.
Old 17th August 2018, 08:15 PM   #2947
Soundhappy's Avatar
Noted Thanks Michael
Old 17th August 2018, 09:26 PM   #2948
I see.
Do you think if any advantage to use SIT instead of MOSFET for follower amp?
Someone told me that the curves of MOSFET in MoFo are "already more ‘triodey’ than a triode.”.
Old 20th August 2018, 08:22 PM   #2949
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
I'm currently gathering parts for a L'Amp build. I'm going for the twin bulb version with a regulated adjustable supply based on the Zen v3 (cap multiplier). I'd like to generate the negative bias from the main transformer, like the schematic that popped up in post #1953 L'Amp: A simple SIT Amp Is there any further information on where that circuit originated from, and more importantly, if it actually works?
Gravity - Making the G since 13.7 billion B.C.
Old 20th August 2018, 08:29 PM   #2950
AudioMaker.Tech
NP posted that.
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 02:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 08:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 15th November 2011 12:41 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 09:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 11:46 AM
