L'Amp: A simple SIT Amp
Old 27th June 2018, 01:58 PM   #2931
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Originally Posted by jolintsai View Post
I could not find detailed high voltage curves, unlike tubes
where the IV curves are usually published, and is within 10-20% tolerances.
Cheers!
Try excellent AudioMaker.tech !
Bunch of informations and softwares for SIT's
: simulation and curve tracer can be useful to test this real transistors on Your work bench
Load Line Tutorial L'Amp 2SK180
Frankentracer part 1
Frankentracer part 2
Apps & Files | AudioMaker
class A amplifiers with full range speakers
sings like angels in heaven
Old 27th June 2018, 07:25 PM   #2932
Soundhappy's Avatar
Use curve tracer first , simulations after to avoid SIT in fire
Old 28th June 2018, 02:50 AM   #2933
jolintsai is offline jolintsai  Malaysia
Thanks Max!
That definitely helps. I've been thinking on what to do with the power up sequence, and the slow start from PowerReg definitely is interesting. I'm just a bit concerned on regulator on power amps - will it limit the dynamics? Based on my listening experience, I prefer unregulated PSU for power amps. It sounds more relaxed - just my 2 cents.
Originally Posted by maxlorenz View Post
The PowerReg (maybe all power regulators) make the voltage climb slowly, so it is sort of a soft start. You will need good quality, high voltage, low leakage capacitors (and high voltage transistors) if you decide to use it. Of course, the negative V bias circuit will be there first if you use a conventional voltage regulator.
The regulated power has the added advantage of reducing the capacitance required for a linear PS.
I attach an App. Note that deals with high voltage regulation.
Good luck and have fun.
M.
Old 28th June 2018, 12:21 PM   #2934
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
Yes, I had this concern too: sometimes I feel the regulator might taint the sound but a well executed VFET amp will erase your concerns in two seconds, probably, plus the bass is great.
The PowerReg, with film caps, ends up being BIG.
My own preference is for a resistor loaded VFET amp (the R protects the VFET, as MR explained before) with a "low thermal memory" input section, like the one I posted before. This really opens up the sound and increases dynamics and transparency.
(I use slightly different local feedback resistor values now)
Good luck.
M.
PS: apparently the 2SK30 JFET has low thermal memory effect, as shown by Hephaïstos, so I will check this with a simple differential pair soon!
File Type: jpg diffamp CFP comp cascodo TOKIN SK180.jpg (99.2 KB, 562 views)
Old 30th June 2018, 06:44 AM   #2935
Ya, high voltage high current PSU are huge.
At the end, I'm probably gonna use a tube driver stage, but for initial phase, anything simple to hook-up will do. Thanks for the schematic and links! I've read Mike's stuff over and over again, hoping not to smoke my limited THF-51s.
Enjoy the 2SK130!
Good luck.
M.
Old 1st July 2018, 05:21 PM   #2936
coolnose is offline coolnose  Europe
coolnose's Avatar
2SK130 or 2SK30 ?
Old 2nd July 2018, 05:07 AM   #2937
Oops. 2SK30.
Old 2nd July 2018, 03:54 PM   #2938
maxlorenz's Avatar
I am already listening to the 2SK30A GR input. Sounds nice. Probably "rounder" than the 2SK170, though transconductance is much lower than the later.
Anyway, the cascoded-CFP input ("Low TMD") sounds better than both, IMHO, more dynamically contrasted, more transparent and with a certain "magic" to it.
M.
Old 9th July 2018, 08:38 AM   #2939
I just wonder, if 2SK180 and such SITs can be used in source follower configuration, like MOFO? Anyone tried that?
Old 9th July 2018, 04:59 PM   #2940
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
I wouldn't recommend the MoFo circuit for a SIT. Some other follower, perhaps. But If I had some 2SK180's lying around, I use them in a CS amp.
Visit AudioMaker.Tech
L'Amp: A simple SIT AmpHide this!Advertise here!
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 02:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 08:55 AM
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 131 15th November 2011 12:41 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 09:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 11:46 AM
Copyright ©1999-2019 diyAudio
