Burning Amp BA-3b (Balanced)
Old 10th October 2018, 03:59 PM   #621
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
you got me there,
was too fast
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th October 2018, 05:08 PM   #622
dodovouk is offline dodovouk
Originally Posted by indra1 View Post
Not so fast. 10Vpp or less is more likely since 28V is at the gate of cascode transistor and 20-30V drop across drain load resistor from 30ma bias.
I am getting 44v p2p now with the standard Burning Amp 3 gain board and rail of 48v dc, why do you say I will only get 10v ?
Old 10th October 2018, 07:24 PM   #623
indra1 is offline indra1  Indonesia
Please calculate operating points or do simulation to understand. The circuit has to be modified to meet output level and gain that you need, but then it may have high distortion. I do not see a good solution coming from that scheme for you.
Old 10th October 2018, 08:35 PM   #624
I proposing to put a more powerful gain/pre amp with 60v gain
Old 14th October 2018, 09:39 AM   #625
There are ImPasse Preamplifier with ImPasse Preamplifier thread by SY and Pumpkin preamp - More Boring Making Thread by ZM that may suit your need better.
Old 14th October 2018, 11:08 AM   #626
neno70 is offline neno70
hi, I was completing the assembly of the components on the pcb of the Burning Amp BA-3 as a guide 6L6, now, I saw this thread on the balanced version, coreggetemi if I'm wrong, in case I wanted to build the version b changes to remove the resistors R5 from 100 Ohm on both channels of the BA-3 board and join them with a 200 ohm resistor? connect the positive input to a channel, the negative to the other channel, mass in common? and at the output of the 2 pcb of power one the positive speaker and the other the negative speakers? quite right ?
Old 14th October 2018, 11:10 AM   #627
Zen Mod's Avatar
picture is confirming your questions ......
shorter - yes
Old 14th October 2018, 11:17 AM   #628
well, one last question; I already have a 1000w 2x18v transformer, but it will not be enough to feed both channels, right?
Old 14th October 2018, 11:26 AM   #629
Zen Mod's Avatar
it depends - how deep you want to set Iq
with 18Vac secondaries , count on 22-23Vdc after rectification and filtering ...... say that you choose 150W of heat per (balanced) channel ..... that's 300W of heat for stereo
1KW will suffice , if Donut is not ringing and buzzing
so , try it
Old 14th October 2018, 11:38 AM   #630
so , try it
Burning Amp BA-3b (Balanced)Hide this!Advertise here!
Burning Amp BA-3 Backbones Pass Labs 2317 30th July 2018 05:12 AM
Burning Amplifier BA-2 Variac Pass Labs 1125 1st July 2014 01:39 PM
Burning Amplifier BA-2 Nelson Pass diyAudio.com Articles 5 14th September 2011 06:11 PM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
