An illustrated guide to building an F5
Old 18th September 2020, 11:10 AM   #1491
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
that's rude, calling 6L6 - dim bulb ...
he's our Bright Bulb
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th September 2020, 12:32 PM   #1492
thomasnadeau is offline thomasnadeau  United States
Originally Posted by 6L6 View Post
^^ do everything Ben said.
( Using the same color wire for both V+ and V- is a pretty dismal idea as he hinted at, Id make a run to the hardware store and get something different for V-. )
Or at least get some green and red electrical tape and use it as a label for the wires. I'll admit I did that a while back because I didn't want to have to unsolder/re-wire.
--Tom
Old 18th September 2020, 04:19 PM   #1493
Chiptech is offline Chiptech
Originally Posted by McQuaide View Post
The dim bulb saves the day
I'd say I get the dim bulb award for the week.
Old 18th September 2020, 04:25 PM   #1494
Dennis Hui is online now Dennis Hui  Canada
Hoopy Frood
Great catch by 6L6!
@Chiptech: Does the bulb test now pass and have you started biasing the amp?
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 18th September 2020, 07:02 PM   #1495
Default Hey I'm on the West Coast [nearly] Tucson time
I'm just starting to undo the snafu I created.
Old 18th September 2020, 11:52 PM   #1496
Default How durable are these
I have extracted Q3 and Q4. I'm wondering how durable these units are? /they seem ok and are built for heat. Any thoughts before i put them back in?
Old 18th September 2020, 11:56 PM   #1497
Zen Mod's Avatar
try them with diode/beep test
if they're not beeping between pins, they're most likely OK
regarding heat durability ........ from personal experience, I know that they're most sensitive to stupidity, everything else goes second
Old 20th September 2020, 09:06 PM   #1498
Originally Posted by Ben Mah View Post
Your power supply voltage is good. Your wiring to the amplifier board looks good.
Looking at the P channel Mosfet (right side of board), the thermistor wire may possibly be contacting the washer/screw. Make sure that only the body of the thermistor is in contact.
Once that is done you are ready for power up with the dim bulb tester. Having two meters for the biasing is best, with one meter set to DC Volts on the speaker out and the other meter across R7, also set to DV Volts.
If all is good, the dim bulb tester should dim after intially glowing bright.
The voltage across R7 should be very low (much less than 1V).
If good, then biasing is next.
Well, I undid the errors with the Mosfets on Q3 and Q4. I double checked everything else on the boards.
But once again dim bulb rules and stays on. I did get a -434.2 reading off the speaker out. didn't get a reading on R7.
Appreciate any input.
Old 21st September 2020, 01:53 AM   #1499
Ben Mah is online now Ben Mah  Canada
1. Your Mosfet or Mosfets may be damaged. Did you test them as Zen Mod mentioned in his post #1497?
2. Your -434.2 at speaker out- what are the units?
3. "Didn't get a reading on R7" -do you mean VDC = 0 across R7 or you did not measure?
4. Did you check Resistance between Mosfet pins and screw clamping Mosfet to heat sink? Check if you did not after remounting Mosfets. Should read high or infinite resistance.
5. Check VDC across R8.
Here are detailed instructions for testing Mosfets:
How to Check a MOSFET Using a Digital Multimeter | Homemade Circuit Projects
As I mentioned in post #1460, I'm not knowledgeable in trouble shooting the rest of the circuit. I've gone as far as I can.
Hopefully Zen Mod will step in and help. He can solve all problems.
Old 21st September 2020, 10:15 PM   #1500
Thanks for the How to Check a MOSFET reference.
Today's measurements:
Regarding #4 above: testing resistance on the MOSFETS I get:
For the right amp P Channel:
Gate OL
Source .047
Drain OL
For the right amp N Channel:
Gate OL
Source .048
Drain OL
For the left amp N Channel:
Gate OL
Source OL
Drain OL
For the left amp P Channel:
Gate OL
Source OL
Drain OL
On R7 I get OL.
On speaker out I get -427.6 mV
On R8 I get OL.
If one or more of the MOSFETS are bad I can replace all of them.
At least I'm learning a lot these days.
And thanks for your interest in helping me debug my handiwork.
An illustrated guide to building an F5Hide this!Advertise here!
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 11:56 AM
Idiots guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
