An illustrated guide to building an F5
Old 17th September 2020, 01:43 AM   #1481
ItsAllInMyHead is offline ItsAllInMyHead  United States
Could someone with better eyes check the values of R21 and R5? It may be worth checking their counterparts also, but I can't see them in the picture at all.
Edit - I got the picture to enlarge on my screen. They look correct at 2.21k.
If you want a friend, feed any animal - Perry Farrell
Old 17th September 2020, 01:58 AM   #1482
KevinHeem is offline KevinHeem  United States
KevinHeem's Avatar
@Chiptech
Check Bottom of R12. It doesn't look like it's been soldered.
Old 17th September 2020, 10:13 PM   #1483
Chiptech is offline Chiptech
Default I checked all the solder points
All are soldered
see photo
Old 17th September 2020, 10:15 PM   #1484
Default Dim Bulb Failure
Well, still have dim bulb failure. I set up to measure as instructed, but still no joy. I looked at all the solder points on the board and they look good to me.
Appreciate any ideas of what to look at.
Old 17th September 2020, 11:25 PM   #1485
Ben Mah is online now Ben Mah  Canada
Did you read the voltage across R7 while you had the power on?
With the power off, set your meter to Ohms and one probe on the Mosfet washer/screw, measure resistance with the other probe on each of the Mosfet pins and the Mosfet thermistor pins. All should read infinite resistance. This is to check to make sure the isolator between the Mosfets and the heat sink and the coating on the thermistors are not damaged and therefore conducting electricity to the mounting screw and heat sink and ground.
Old 17th September 2020, 11:36 PM   #1486
6L6 is offline 6L6  United States
6L6's Avatar
You powered up with the amp channel attached and the light turned on and stayed on bright?
Old 18th September 2020, 12:57 AM   #1487
Yes. And I got OL readings.
Old 18th September 2020, 02:20 AM   #1488
6L6's Avatar
Take the fender washers off and double-triple check you have the IRF240 at Q4 and the IRF9240 at Q3
Old 18th September 2020, 05:51 AM   #1489
I have Right Q3 is wrong and Left Q4 is wrong. They need to be swapped.
thanks for helping me find this.
Old 18th September 2020, 11:07 AM   #1490
McQuaide is offline McQuaide  United States
The dim bulb saves the day
Mark Micro Seiki DDX-1000>Pearl 2>BA-3 FE>F5>Mirage OM-7 Towers
An illustrated guide to building an F5Hide this!Advertise here!
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 11:56 AM
Idiotīs guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
