Initial setting of F5 bias--help, please!
Old 29th March 2020, 07:36 PM   #41
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
P3- leave it out or strictly set to exact middle value
these are for deliberate setting of THD spectra, and if you need to ask, you are still not prepared to use them
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 29th March 2020, 07:39 PM   #42
ItsAllInMyHead is offline ItsAllInMyHead  United States
I'd recommend reading 6L6's build guide - the functions of all three pots and how to set them prior to the first power-up will save you some time and effort. It's all in the first page or two. If you don't set the bias pot properly prior to power up... you could blow another set of FETs.
Edited to add... and what ZM said
If you want a friend, feed any animal - Perry Farrell
Old 2nd April 2020, 12:38 AM   #43
mhouston is offline mhouston  Australia
mhouston's Avatar
I have built a F5 turbo for another with purchases from the Diyaudio shop. Higher quality components and matched jFETs We’re used. But I can’t get the amp brds to bias.
Using a variac with only 40VAC going into the amp for 2.65VDC on the brds the 0.47 resistors have 1V across them. It doesn’t matter which of the two trim pots (10 turn) are on full anti-clock or fully clockwise turned in any or all combinations the bias doesn’t change. Also there is 0.33V DC offset stress the speaker posts. The resistors are slightly warm.
I have checked all components resistors and jFETs a number of times and all appear to be correct. At assembly each component was quad checked against the schematic at assembly.
Any clues why I cannot bias off the power FETs. They appear to be fully on and conducting? Anyone else experienced this?
Old 2nd April 2020, 12:47 AM   #44
Zen Mod's Avatar
any pictures to share with us?
while powering amp for first time , you don't have any right or freedom to use any other position/setting of trimpots than total zero, confirmed with ohmmeter across parallel resistors (parallel to trimpots)
Old 2nd April 2020, 12:58 AM   #45
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Why the variac and what rail voltage were you getting? And what voltages do you get across R3 and R4?
As ZM said, you should start with P1 and P2 at minimal value (adjust them so
that R5 and R6 measure close to zero resistance)
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 2nd April 2020, 01:45 AM   #46
mhouston's Avatar
See above for the voltages DC and AC.
File Type: jpg DB7E93CE-06CB-42A2-8C7B-E05BE4FD3877.jpg (863.0 KB, 136 views)
File Type: jpg 6F45CB6D-9D49-41AA-86A6-460C4B60C6CE.jpg (701.3 KB, 135 views)
Old 9th April 2020, 02:33 PM   #47
Dline is offline Dline
Default F5v3 build guide link pls
Can someone please send me the build guide from 6L6 that describes the 3 pots and how to set them. Thank you very much!
Old 9th April 2020, 08:40 PM   #48
Use this one to start...
Firstwatt F5 amplifier v3 - diyAudio Guides
Then for more depth re: P3, you can see this and his YouTube video.
An illustrated guide to building an F5
Old 16th April 2020, 03:03 PM   #49
b4bz is offline b4bz  Canada
There is a YouTube video? Would love to have a link since I can't find it in the thread.
Old 16th April 2020, 03:28 PM   #50
LMGTFY -
setting P3 pass amp - Google Search
First result -
Adjusting P3 - a video
Initial setting of F5 bias--help, please!Hide this!Advertise here!
P3A bias setting werfi Solid State 15 8th February 2010 07:03 AM
P3A bias setting werfi Solid State 0 31st January 2010 07:11 PM
Setting Bias kptseng Solid State 9 8th March 2008 01:56 AM
bias setting ben goh Solid State 8 14th August 2006 04:26 PM
Problems with bias setting Cicero Solid State 5 21st January 2005 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
