Pictures of your diy Pass amplifier
Old 2nd March 2020, 08:33 PM   #5021
Todd Mills is offline Todd Mills  Canada
Thanks Guys
6L6 - The amp sounds smooth with really great bass.
Old 3rd March 2020, 11:39 AM   #5022
thompsontechs is offline thompsontechs  United States
thompsontechs's Avatar
Nice work Todd!
JT
Who's your Daddy? Pappa of course.
Old 17th March 2020, 05:31 PM   #5023
TungstenAudio is offline TungstenAudio  United States
Default "Penultimate" Zen V4
This is still a work in progress. There are challenges to using these particular PCBs, which are not well documented. I really wish there were good boards available from the store.
Transformers are from some of the old Hafler amplifiers that I've collected over the years. Unloaded secondary voltage is 48V, and they exhibit some sag when under ~ 2A quiescent current load. Internal regulated rail voltage ends up being 47.7V, with a zener diode stack totaling 51.8V. Using IRFP150 in the regulator and current source positions, FQH44N10 in the signal amplifier position.
Old 22nd March 2020, 06:25 PM   #5024
elwood625 is offline elwood625  United States
elwood625's Avatar
Between Covid-19 and winter weather that won't go away, I've had time to finish projects I started awhile ago.
First up, was the stereo ACA v1.6 using premium parts, I used the schematic and parts list from TungstenAudio. Using an old Hafler DH-200 amp, I gutted and cleaned the enclosure and used it for the ACA. Without the massive transformer inside the enclosure, it was far to light weight, along with holes in the bottom from all the Hafler parts installed. So I used sound deadening material from 3M, peel and stick about 4mm thick, I cut two pieces for each side of the lower panel, added heft and quieted the inside of the enclosure.
I'm using a Meanwell power supply (24v 6.5A) from Parts Express, with a voltage adjustment I dialed in 24 vdc.
I kept one of the "speaker" fuse holder for the 115 vac line. The on-off switch is illuminated red when on, instead I'm using the amber "overheat" lamp for an indicator. (I've owned these amps since 1979 and only once did I ever see the ambler light go on.) The other fuse holder position I used for the mono-stereo bridge switch.
Of course, each PCB has a blue LED which are visible from the top and bottom through the vent holes.
The amp is about 8 hours old now and playing music for the next couple of days to break it in.
Photos show the ACA version on top of an original Hafler DH-200.
ACA v1.6 monoblocks, Balanced Zen Line Stage, M2x, Aleph J, H2, B1 Korg triode, 12AX7a Phono amplifier, Balanced B1 Korg triode, 6FG6 "Magic Eye" tube VU meter
Old 22nd March 2020, 07:01 PM   #5025
That's a good looking ACA build. I love the clean lines of the old DH-200 chassis. I have one or two of those lurking around as well. Looks like you found a good way to mount the boards. The amp is definitely lighter with the SMPS inside instead of the big iron transformer.
There is a variation of a capacitance multiplier which can be used as a soft start to allow a large bulk capacitor to be used after the SMPS on the power rail. Look for the Mr Evil / PMI cap multiplier in the power supply forum. Jason Kuetemann has a slightly simplified version as well. Since this uses a P-channel Mosfet, it may be adjusted for a low dropout of ~1 Volt or a little less. The MeanWell SMPS can be adjusted to compensate for the dropout to keep your amp's rail voltage the same.
Old 26th March 2020, 06:45 AM   #5026
batty is offline batty  Australia
This is my PASS PC audio stack.
I have gone from 85 watts class AB amplification to an ACA.Gone on to the M2X.
Old 26th March 2020, 12:07 PM   #5027
Mod Man is offline Mod Man  United States
Aint it fun.
Old 26th March 2020, 02:11 PM   #5028
Sweet!
Old 26th March 2020, 10:56 PM   #5029
zman01 is offline zman01  Bangladesh
Nice collection batty!
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
