Pictures of your diy Pass amplifier
Old 18th July 2019, 02:54 AM   #4781
bk856er is online now bk856er  United States
bk856er's Avatar
yoshida, that is quirky and lovely at the same time and also showcases the meticulous details inside. Bravo!
BK
Old 18th July 2019, 08:50 AM   #4782
esprit is offline esprit  Europe
A breath of fresh air
Old 18th July 2019, 11:43 AM   #4783
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Originally Posted by vdi_nenna View Post
Ah, minor details! Just reverse one of the fans.
Nice case work!
That is an absolutely brilliant response. Experience reveals itself.
Good decisions come from experience. Experience comes from making bad decisions. (Mark Twain)
also, Everyone has a plan, till they get punched in the mouth. (Mike Tyson)
Old 24th July 2019, 07:51 PM   #4784
BigE is offline BigE  Canada
BigE's Avatar
Nice case work!
That should work perfectly. Great Idea!
Old 25th July 2019, 05:11 AM   #4785
Btsd is offline Btsd  Australia
Reversing one of the fans might cause some short circuiting of the air. Air drawn out by one fan is then turned around and then sent straight back into the box by the other.
I am not sure how much the side plates are acting as heat sinks and drawing away the heat from the bottom plate but by spacing them with washers reducing contact with the base plate may reduce this affect.
May be a few more holes in the base plate would be better.
Just my thoughts.
I do like the build though.
Tony
Old 25th July 2019, 05:52 AM   #4786
batty is offline batty  Australia
It is the arrangement we use at work with test equipment, on 24/7 no probs, gets hot without the fans though
Townshend Rock II, My new TT since 1986.
Old 25th July 2019, 06:25 PM   #4787
BigE's Avatar
This is probably minimal, due to the discharge velocity of the fan. I would be concerned only if the fans were moving very slowly.
Old 25th July 2019, 06:39 PM   #4788
6L6 is offline 6L6  United States
6L6's Avatar
... Just add a few washers to make space around the lid and the air will have lots of ability to move and exchange. No fan reversal necessary.
Old 26th July 2019, 01:35 AM   #4789
BluesTM is offline BluesTM  United States
Default This is my F5, there are many like it...
I built this amp to go between an Audio Research LS3 and a pair of Altec Model 19s. The LS3 has way more gain than it needs (18dB) and the Model 19s can play more than loud enough with little power (99dB/watt). It seemed like the 15dB of gain and 25watts of power would not be a problem. So far they've been a good match.
I pretty much went with the build guides from 6L6 and JojoD818 which is why it looks pretty much like your standard build I guess. However following the guides seemed the best way of assuring the build would be successful. I'm very happy with the results. Despite being only 25 watts it drives the 19s with more authority than the Dynaco Mark III clones I built for them last year and those measured out at just over 60 watts each.
The boards and F5 parts kits came from the DIY Audio Store. The jfets came from Punkydawg on ebay. They were perfectly matched per my DCA75 and the amp biased up easily, no fuss at all. The chassis is the Deluxe 4U. From the temperatures I'm seeing anything smaller would probably need a fan. The transformer is the Antek 500VA model. It took a lot of space so instead of cramming everything into the bottom I mounted the cap board on the front. I ran the DC wires out the top and laced them down so they wouldn't rub against the lid.
While running the amp in on the bench I did do some testing to make sure I wasn't missing anything. Gain came out to 16dB and matched on both channels. THD+N 1watt/8ohms measured around 0.0089% and S/N for that same condition 85dB in one channel and 86dB in the other. That actually probably represents my test setup more than the amp since redressing and moving cables around could change the result by 2 to 4 dB. BW was a surprise with a -3dB point around 520KHz with no ringing on square waves and stable operation so far.
I think it's a credit to the design that so many people in so many ways can build something that performs that well that easily over and over again. You can see from the photos there is nothing exotic about it at all.
Old 26th July 2019, 01:49 AM   #4790
Eric is offline Eric  United States
Eric's Avatar
Great looking amp and a nice bench as well! Congrats on your new amp!
It's waaaaay too late now, but it would be interesting to know how many amps have been built as a result of this website being around for the last 19 years!
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, ACAs, FHXL & TB 1772 speakers
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2019 diyAudio
