Pictures of your diy Pass amplifier
Old 23rd April 2019, 06:11 AM   #4661
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Originally Posted by elvenears View Post
Burning Amp Salad
Exactly!
"The geek shall inherit the earth"
2019 Burning Amp is in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 7th May 2019, 12:09 PM   #4662
rhthatcher is offline rhthatcher  United States
An F5 is born!
I recently rebuilt several Rawson amps for me and a friend - 2 Stereo Aleph Mini J's, 4 Aleph J Mono blocks, and a PSU on another F5. All had missing safety earths. IIRC, all but one had a single rectifier. Some wiring was scary. They're all fixed up now. You can see the pic of the old PSU boards from the bone pile. I learned a ton in the process.
The newest project I completed last night was taking a Rawson Gainclone and using the chassis to make a nice F5. Only original parts are chassis, feet, RCA's, LED, and binding posts. Thanks to this site I learned several things incorporated into the build. I used a quasimodo jig to measure snubbers. I used Jeff Young's PSU board design to make a dual rail decoupled power supply. And I have to give a huge THANK YOU to Jim "6L6" for the support over the past months. And yesterday, he was a huge help in demystifying the F5 Biasing process. It's a bit tricky, but he made it easy for me.
The amp sounds fantastic on the test speakers. Next I'll put it in the main system.
Old 7th May 2019, 11:57 PM   #4663
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Well done, Randy!
Old 8th May 2019, 01:10 AM   #4664
Eric is offline Eric  United States
Eric's Avatar
Yes, Well done again! In a sad sort of way, there seems to ALWAYS be a market for cleaning up the messes that others make
My DIY Basement Theater, Aleph-X Amps, LDR based BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, M2, Aleph-J, MoFo, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 13th May 2019, 05:17 PM   #4665
Nitram86 is offline Nitram86
Default MY F5TV3
My F5TV3.
Old 13th May 2019, 10:02 PM   #4666
Mod Man is offline Mod Man  United States
The last image says it all.
Old 14th May 2019, 07:12 PM   #4667
Danger Mouse is offline Danger Mouse  Germany
Danger Mouse's Avatar
Do the heat sinks work in this orientation? enough Ventilation? Do you have a hole in the Bottom plate under the sinks?
I also thougt About this way to mount the heatsinks. but be worried they may get to warm.
Old 15th May 2019, 01:23 PM   #4668
WE have used two 120mm fans in each. They kick in when needed and stabilize the temperature. Lots of messing about and a custom fan controller with thermistors but so far so good. They are running at 46c and maintain this constant temperature.
Old Today, 04:56 AM   #4669
BadToTheTone is offline BadToTheTone  Canada
Default ACA v1.6 Monoblocks
Got 'em done, finally. Here's a pic of them sitting on top of their little brothers for comparison. Look good, sound great.
Old Today, 07:32 AM   #4670
nicoch58 is offline nicoch58  Europe
I recomend Italian Extra Vergine Olive Oil. Makes the amp sing like Pavaroti.
you must add some Amarone
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2019 diyAudio
