I am considering a DIY B4 variant for my closed subwoofers and my Quads, so no dipole compensation necessary. But I do not need crossover frequencies above max 200 Hz. So one option is to skip the resistors and DIP switches for the higher frequencies, another is to improve the granularity below 200 by changing the values. But maybe the original 25 Hz steps is enough.
(But it was a good exercise to reverse engineer the B4, even if my version should fail to surface.)
The DIY B4 that is planned does not come with steps, it is fully continuous with the help of trim pots. You need to set these to get the desired slopes.
Yes. I know that. Still, I liked the DIP concept quite a lot.
- Pass Labs B4 crossover questions
