I have just finished my F5 and plan to use it to drive a pair of 15" co-ax
drivers in an open baffle set up.
These drivers are 8 ohm and have a sensitivity over 95db.
The set up will also have 2 lo-frequency 8 ohm drivers in parallel driven by
a 370 watt plate amp.
It has been suggested that I use the high level inputs on the plate amp connected to the output of the main(F5) amp.
My question is, will this be a problem for the F5??
I don't want to damage my F5 in any way.
Depends.
Measure the DCR of the high level input first. It ought to be high.
In which case it will not be a problem in terms of loading the F5.
However some people would argue that the xtra speaker wire will effect the overall sound of the amp.
Myself, I would keep the two beasts separate and use a buffer for the line level run to the plate amp... the Pass B1 is one example of a buffer.
Just my opinion...
Just my opinion...
