In this link (below) Nelson Pass suggests a method to throw away some gain when operating an op amp at low and unity gains.
http://www.diyaudio.com/forums/solid-state/6558-opamp-inverting-input-sounds-better.html#post67880
I understand the principle but can't come up with a schematic for the method he suggests:
"If the circuit has less than 20 dB gain, I toss some away.
With an inverting amp, a resistor from the - input to ground
will do it. If not, then resistance from both + and - to
ground is used."
My best shot at the inverting configuration is shown below.
For the non-inverting config i can't come with anything that isn't simply throwing away input or changing the gain in the feedback loop.
I am interested in trying this out with an amp i am building that is based on Juma's schematic which is a version of the GC SuperSymmetry also proposed by Nelson. Juma's schematic can be seen here with opamp input buffer:
http://www.diyaudio.com/forums/pass-labs/36398-gc-supersymmetry-23.html#post1710811
and here with B1 style input buffer:
http://www.diyaudio.com/forums/pass-labs/36398-gc-supersymmetry-23.html#post1995610
I plan on using a LME49710 which has 140dB of open loop gain as the input buffer and am preparing for the possibility that it may be near oscillation at unity.
The alternative approach i am considering is having less gain around the opa1632 and adding gain to the LME49710. Even if i go this way i would still like to better understand Nelson's idea.
Thanks for helping.
ground is used."
Thanks for helping.
Nelson, thanks for the confirmation on the inverting configuration as well as increasing this threads view count by almost 3X.
Does anyone want to take a shot at the non-inverting configuration. I can't seem to do it without changing the gain or throwing away input.
Merry Christmas
Merry Christmas
