Pearl Two
After a few years of excellent listening my Pearl II has developed a pop on startup in the left channel. Otherwise, it's still fine. Any thoughts before I start meddling?
Readjust P1 for "0" at the test point.
Does it "pop" every time afterward? It may be that one or more of the electrolytic capacitors has not fully discharged, that the poz and neg rails are charging up at different rates, or that there is a fault with C13. In any event, at turn-on, a charge will move across C13 if there is a voltage differential at the junction of R16 and R17.
You could also decrease the value of R18 from 100k to discharge C13 more quickly.
Helpful if you have a scope
Reactions: 1 user
Thanks for the suggestions. So far I have replaced the ZVP to no avail... still pops in the left channel on startup, whether after a lengthy idle or soon after switch off. Will check the P1 in the next day or so. Unfortunately don't have an oscilloscope.
Unrelated, I changed out the C12 and C16 capacitors for a 0.33 uF K40Y-9 capacitor. While the overall presentation seemed a bit richer, the bass was a bit loose and the top end not as vibrant. After a period of listening I decided it was simply boring. On the basis of a one to 100 ratio for a bypass capacitor that has tightened things up in the past I bypassed the K40s with Russian 5100 pF silver micas and am delighted. Everything sounds better. The cadence and timbre shows up wonderfully with strings, and orchestral, rock and jazz are all far better. I have no idea how it all measures but I am very happy!
Reactions: 1 user
To update: Sound deteriorated somewhat so checked voltages which were down around Q3 (ZTX450) so replaced without success. Replaced Q1 and voltages then comparable with other channel -- around 7v. This is still lower than the 10v in the schematic but comparable with those observed sometime ago by another poster.
Have reduced the silver mica bypass capacitor to 3000 pF. They take a while to break in and show their true colours. 3300 pF should be ideal.
