FirstWatt J2
FirstWatt J2
Old Today, 12:43 PM   #1651
thompsontechs is offline thompsontechs
thompsontechs's Avatar
Originally Posted by MEPER View Post
If you have the choice building a "J2" using 120R100 vs. 120R125 what would be recommended? …...will it be almost "same same"?
I would/am going with the former, but Papa makes remarks about your very question in the thread below, check post 3.
Here
The quote is thus:
"In practice there is very little difference between the R100 and
R125 versions for our applications. I get just about the same
numbers in the J2's with either part."
NP
Old Today, 01:46 PM   #1652
MEPER is offline MEPER  Denmark
MEPER's Avatar
Thank you.....good to know that the difference between them is very small for J2 application.
Old Today, 01:48 PM   #1653
@ Meper
Glad I could be of help... since I'm new, it's a rarity.
Who's your Daddy? Pappa of course.
Old Today, 02:33 PM   #1654
6L6 is offline 6L6  United States
6L6's Avatar
FirstWatt J2
Also Papa reports that using the R100/R120 in the CCS position makes no real effect on the sound, so you might as well use a mosfet there and save the expensive parts.
Old Today, 03:29 PM   #1655
MEPER's Avatar
I am in for a quad of 2SK3497 in the group buy ….so the plan is to use these for the CCS and then either R100 or R125 as the output transistor.
Don't know why I ended here…...just built the M2X.....and then I got a set of the "long skinny PCBs".....and now I have almost all parts for the J2 amp......and with choice of R100 or R125 (big problem!).
Old Today, 03:46 PM   #1656
6L6's Avatar
FirstWatt J2
Why?
Because.
That’s a perfectly suitable reason.
Need to build them all.
Old Today, 04:28 PM   #1657
MEPER's Avatar
Yes, and it is a good mental relaxing hobby to be concentrated on a build and listen to it afterwards…….some "greediness" probably also :-)
Old Today, 04:32 PM   #1658
@Meper
YouTube
Old Today, 04:37 PM   #1659
MEPER's Avatar
Yes.....probably something like that :-)
Old Today, 05:07 PM   #1660
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
FirstWatt J2
My personally feeling is that as long as I can build, I will do so,
just because it's fun to build and listen.
(I just counted that I have now a dozen amps, all quite good. So I do feel
a bit bad that they don't get a much use as they should.)
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
FirstWatt J2Hide this!Advertise here!
An another way to Firstwatt F1? Idefixes Pass Labs 10 5th July 2017 01:02 PM
Subwoofer and Firstwatt F1 tgrauss Subwoofers 10 3rd June 2009 05:29 PM
Fostex and Firstwatt in car? Ipanema Car Audio 2 11th February 2008 06:32 AM
FirstWatt.com Rory Christ Pass Labs 121 31st May 2004 08:02 PM
Copyright ©1999-2019 diyAudio
