2SK170 matching
2SK170 matching
Old 27th March 2009, 07:29 PM   #11
audiodan is offline audiodan  New Zealand
Hello All
Thanks for your knowledge Much Appreciated !
Another Question.
I see that a dual supply is needed but I was gonna use the same transformer used with my AP1.7, have the 1.7 and pearl in one box and power supply in another. Supply is 30-0-30v 160VA. Yes i know its overkill but the price was right.
Should I swap for two 0-30 transformers, in which series them up and power ap1.7 and use seperately for pearl?
Cheers
Old 27th March 2009, 08:15 PM   #12
steenoe is offline steenoe  Denmark
steenoe's Avatar
What really needs matching in the Pearl (as with all RIAA's ) is the equalization components. Those parts are mainly R19, R22, R23, R24, C10, C13, C11 and C12. The main concern is to match them so they are the excact same in each channel. Doing this will greatly add to the soundstage, both in width and depth. The Pearl is capable of delivering an great soundstage, if this is taken care of. The excact value is not as important as being the same between channels. Mrupp mentioned this, and I think it deserves to be repeated
You would also do good by matching at least Q8-Q11 to some degree, since they sit in //. Not really needed though, as mentioned above.
Old 29th March 2009, 07:40 AM   #13
Thanks for that steenoe
I take it there is no problem with not using a dual supply.
Old 21st January 2016, 04:06 PM   #14
ci11 is offline ci11  United States
Originally Posted by Nelson Pass View Post
Get a 5 to 13 volt supply and a DC voltmeter. Connect the +V to the
Drain, connect the Gate and Source together to a 100 ohm resistor,
and connect the other lead of the resistor to ground.
Measure the voltage across the resistor, which gives the Idss. 1 volt
= 10 mA of current.
Try to measure all devices under the same conditions, temperature,
and duration of test.
Mr Pass,
I know this is an old thread but would you mind checking the attached circuit to see if this is what you mean in the post regarding checking Idss?
Thanks!
Old 21st January 2016, 04:44 PM   #15
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
2SK170 matching
Is this matching different than Idss matching? This is Vgs matching?
I build, therefore I am.
Do not create problems where there are none.
Old 21st January 2016, 04:52 PM   #16
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
2SK170 matching
trick question - what is voltage between gate and source , on that picture ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 21st January 2016, 04:57 PM   #17
= 10 mA of current.
ZM,
Not a trick question, only following papa's instruction as highlighted above in his message.
Old 21st January 2016, 05:09 PM   #18
Zen Mod's Avatar
2SK170 matching
circuit is good , but I was (sort of ) replying on vdi_nenna's post .....
Old 21st January 2016, 05:12 PM   #19
ZM,
Thanks for the confirmation. I will go rig this up.
Old 21st January 2016, 05:20 PM   #20
vdi_nenna's Avatar
2SK170 matching
I don't know. 1 volt?
2SK170 matchingHide this!Advertise here!
Wanted 2sk170 V Sergelisses Swap Meet 0 28th February 2009 02:35 PM
2sk170, 2sj74 enzedone Parts 4 21st December 2008 05:38 AM
Teflon PCB, 2sk170 and j74 maxpou Solid State 10 25th April 2008 06:03 PM
Questions regarding matching of 2SK170 Ruach Solid State 7 11th August 2006 04:01 AM
2sk170 Substitute mr l Parts 2 8th June 2004 10:49 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
