F3 Builders Thread
F3 Builders Thread
F3 Builders Thread Please consider donating to help us continue to serve you.
Old 14th February 2020, 05:50 PM   #741
Kononowicz is offline Kononowicz
Ok, time for few pictures. The schematics and BOM I used are from this document First Watt - F3 (JeffYoung) - Google Docs, with R8 at 1.5 Ohms.
As you may notice, Q4 ZTX450 is soldered in opposite direction to the silkscreen marking on the board. It is my understanding that it's the correct way, considering that Q4s Collector has to be connected to Q3s Gate through R15, I have marked the way I see it on the picture.
Old 14th February 2020, 06:04 PM   #742
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
F3 Builders Thread
Q4 is correct. The E-line shape is truncated from the TO-92 shape, but in both cases the writing faces the edge of the board.
Old 14th February 2020, 06:08 PM   #743
JeffYoung's Avatar
F3 Builders Thread
Did you connect both the power ground and the signal ground to your PSU 0 volts? (The pictures show the power ground connected, but the ground connection below the Lovoltech appears to be empty....)
Old 14th February 2020, 06:11 PM   #744
JeffYoung's Avatar
F3 Builders Thread
BTW, when you gave the voltages, when you said "Source" did you mean the "high side"? (That's actually the drain on an n-channel MOSFET.)
Old 14th February 2020, 06:21 PM   #745
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F3 Builders Thread
speaking of ....... I hope you didn't powered that without proper heatsinking
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th February 2020, 06:42 PM   #746
Hi Jeff, thanks for replying!
the signal ground, of course! For some unknown reason I have convinced myself that it doesn't have to be connected to the PSU ground. It would take me really long time to solve this one on my own. Tomorrow I will make connections and try how it works.
As for the voltages, I've meant the Source pins of Q5 and Q2, marked with 41V/3.5V on the schematic.
Cheers!
Old 14th February 2020, 06:45 PM   #747
I did not, I had it clamped to a steel bar acting as a temporary heatsink, which was just not very handy for taking pictures.
F3 Builders ThreadHide this!Advertise here!
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 04:31 PM
A-X IP Issues (split from Builders thread) tomchaoda Pass Labs 107 16th October 2011 03:05 AM
one for the box builders offroadbum Car Audio 2 11th October 2004 10:19 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
