The Pass Pub: The High-End Off Topic Thread
@seventenths interested in being able to turn on/off, in this case for the Aleph J.
If the 12V is constant, it's just like ZM noted. Simply a relay with a 12V coil and contacts rated for the load. A diode should be placed between the coil terminals (line to positive) and you're good. If the 12V is a pulse, you're in the same boat as those using a momentary switch. There are threads/circuits here, Rod Elliott's site and elsewhere as well as really inexpensive flip-flop modules on amzn etc. If you go that route, watch the contact ratings. If lower than necessary You can always throw a more robust relay with that output. Cheers
  • Thank You
Reactions: 1 user
Official Court Jester
Joined 2003
from my (limited) experience, I don't like anything Jadis
not so judging by SQ (meh) but by simple factor of me being totally and utterly exclusive - 12AX7 is having no place in any amp, at least if not used in some peculiar and novel way**
and that's not the case with Jadis
as fully chromed Harley Davidson
gimme Victory
**for peculiar and novel (sort of) one need to look at Tim De P. constructions, for instance
Reactions: 1 user
Hello stajo,
hello esprit
and hello to all others out there in this galaxy,
Similar situation here in southwest-germany: rain, rain and above 600m snow!
We have a saying: April, April, does what he will...
My bikes have been awaken in March. The cubicinches are waiting to work again and putting the hot
rubber to the ground...
Because of the horrible weather - some listening to good music and preparing two nice cases for
another PEARL 3.
Enjoy the weekend
Cheers
Dirk :cheers:
Reactions: 1 user
I even matched the 0,5% Dale CMFs. No phase shifts here buddy, oh no. 24dB active filter lowpass and highpass signal at crossover frequency 1040 Hz. Left and right alike.
Reactions: 1 users
One of my favorite demo/evaluation tracks is Nils Lofgren, Acoustic Live, Keith Don't Go. This is an acoustic version of a hit that Nils had in the 70's and most people say it is dedicated to Keith Richards. Keith probably should be on that list, he'll probably outlive us all!
Though I've heard it said, Time Waits For No One :rofl:
