I have a Totem Arro speakers, they are 87 db / 4 Ohm
Can some one tell me witch Aleph should i build for this great speakers , now i have a 80W REGA AMP, but i want to try a class A amp.
I was thinking of a Aleph 5 but with more bias corrent, is it a good choise.
Best regards,
Best regards,
Aleph 2+
I'm building a set of Aleph 2 amps for use with my Piega P5 LTD. They are also around 87dB/W and 3-4 Ohms (4 ohms according to spec, but the curve is more on 3 ohms for the mid-range frequencies).
I was planning to beef up my A2's by adding 2 sets of output devices, so 4 fets extra per amp, putting the bias up to 4A. The heatsinks and Power Supply should be able to take that extra dissipation without a sweat (PSU rails will probably be around +/-50). The increased dissipation will get around 400W per channel.
The only thing I'm not sure about is whether I need to modify the rest of the circuit as well?
Bakmeel
Bakmeel
