B1 Buffer Preamp
B1 Buffer Preamp
Old 4th November 2019, 03:49 PM   #4551
bassnkeys is offline bassnkeys  United States
Default "... impose..."
I have had the opportunity to compare the B1 to a number of highly regarded preamps and can say it does less to the signal than any of them. It is so "not" there that I can say it is the end of the line in my search for a front end.
The most important function to me is that it gives me a convenient way to shield the downstream items from any on/off/switching transients.
A top quality volume pot is important.
Dave in MN
overcast, flurries, 33f
Old 5th November 2019, 03:22 PM   #4552
BigE is offline BigE  Canada
BigE's Avatar
I suspect , the B1 sounds most like it's attenuator, though I have not tried swapped ng out, reports of sonic impact of the attenuator do exist.
Old 5th November 2019, 03:33 PM   #4553
Spe@kerBox is offline Spe@kerBox  United States
Spe@kerBox's Avatar
B1 Buffer Preamp
I've had good luck with ALPS blue velvet on mine.
Old 5th November 2019, 03:58 PM   #4554
WKCox is offline WKCox  United States
WKCox's Avatar
B1 Buffer Preamp
Same here. I swapped out the ALPS for a Goldpoint V24 attenuator. No noticeable change in sound quality but theoretically better channel tracking. Not that I had any problems whatsoever with the ALPS.
Pass F5, M2x, ACA, B1, B1 Korg; Audio Research ST-70-C3; Dynaco ST-35; Audio Electronic Supply SE-1; Elekit TU-8500; Hagerman Bugle; Scan-Speak Solist MTM; Selah SA-1; Seas Loki; Cavalli eXStatA; Millett Hybrid MAX, Hybrid MiniMAX
Old 5th November 2019, 04:07 PM   #4555
Default Volume Pots
I have used the Alps Blue and find it first rate. I have also tried a couple Glasshouse stepped and as I noted before a Goldpoint V24 with their SMD resistors. All have been very good with the Alps and the Goldpoint requiring no cleaning ever.
Old 5th November 2019, 04:53 PM   #4556
BigE's Avatar
I'm using a TKD. No complaints.
Old 5th November 2019, 07:40 PM   #4557
WBS is offline WBS  United States
B1 Buffer Preamp
I used the same parts that First Watt used in the commercially available B1, the trusty PEC pots. When I replaced my Parasound pre it was like removing a cotton blanket from in front of the speakers!
"Only those questions that are in principle undecidable, we can decide." - Heinz von Foerster
Ethics and Second Order Cybernetics
Old 5th November 2019, 08:14 PM   #4558
brucew268 is offline brucew268  United Kingdom
Have you compared TKD to Alps Blue or others and have a sense of its sound character?
Old 6th November 2019, 02:02 PM   #4559
BigE's Avatar
I did no comparison. Some say it's better. I can't tell you for sure. Others swear by the Lightspeed. now that's interesting.
Old 6th November 2019, 06:24 PM   #4560
Itsmee is offline Itsmee  England
Itsmee's Avatar
B1 Buffer Preamp
I preferred the Noble over the Blue Alps
I preferred my LDR over the Noble
I prefer the Muses over the LDR
My system has completely changed since using the Alps, I must try it again to see if I like it more than the Muses
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 09:40 AM
Copyright ©1999-2019 diyAudio
