B1 Buffer Preamp
B1 Buffer Preamp
Old 5th October 2018, 07:07 AM   #4491
mjf is offline mjf  Austria
using a res as a ccs is the simple solution ("poor man's ccs" ).
imho a fet ccs has an "output res" in the 100k region............if you want to substitute the fet ccs with a res you should use 100k or better - but this does not fit into most schematics (exept some tube amps or sowhat).
have a look into the textbooks.........
Old 6th October 2018, 01:39 AM   #4492
helitim is offline helitim  Canada
mjf,
Thank you for your response. Currently I am using the ARRL handbook as a reference. I also have a couple of Douglas Self's books, and Bob Cordell's book. Approx 14 years ago I was taught some of this stuff in school, but haven't used it in years, and didn't get very deep into it at that time.
Now I am trying to recover the knowledge I had, and add to it . I like to understand how all the components interact and create the finished product.
- Tim
Old 7th October 2018, 05:20 AM   #4493
I was using bad models in spice. I found better ones, and now I can simulate the same output for I-R1 or I-R3 using an 833.33 ohm resistor.
Old 10th October 2018, 09:29 PM   #4494
mjf,
When you say "output res", are you referring to the resistance of the preamp, as seen by(from the perspective of) the next stage "looking back"?
Old 11th October 2018, 09:32 AM   #4495
........."output res" correctly: output impedance of the drain lead J2....
(output res is a simplifikation).
Old 16th October 2018, 04:40 PM   #4496
So assuming that the output signal of the above two circuits(post 4493) behaves the same with JFET 2, or R9(~830k) installed; would it be correct to say that the both have different output impedances? Do you think it would be safe(won't damage anything) to build both and compare? This is completely a thought experiment for me at this point, so that I can better understand Nelson's choices in this design. Thanks.
Old 16th October 2018, 08:50 PM   #4497
imho output impedance is dominated by J1...........
R9 is 833ohms - not 833kohms. you can try out 910 or 820ohms.
the ccs should give better linearity, that means lower distortion.
a distortion sim (fourier analysis) could show this.........
Old 16th October 2018, 09:12 PM   #4498
Perfect, that's what I thought. Now I understand what you meant.
I used 833 in the sim, I don't know why I wrote 833k. Just got ahead of myself I guess!
Thanks for all the help!
Old Yesterday, 09:08 PM   #4499
nilsW is offline nilsW  Sweden
Default I managed to put my B1 together!
I am now a proud owner of a working B1!
No critical listening just two hours testing that it works hooked up to an old amp and it does!
This is my first build ever, and this thread has been a great help. Thanks to everyone!
It is the kit from Jim`s audio.
For C100/C200 1,5 uF caps were supplied. Normally these are 1uF. Should I change those to 1 uF?
File Type: jpg 2BFBED1F-77E1-4CB4-9619-CCAEA7200F85.jpg (692.6 KB, 34 views)
File Type: jpg 14030FFA-BB79-4435-8118-F120B62C5623.jpg (520.8 KB, 33 views)
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
