F5 power amplifier
F5 power amplifier
Old 8th October 2019, 01:36 PM   #16091
tooppy is offline tooppy  France
tooppy's Avatar
Originally Posted by Dennis Hui View Post
Where did you source the caps originally?
From Mouser.
Old 8th October 2019, 01:41 PM   #16092
tooppy's Avatar
I just change the cap, look at measures, seems good (considering I am looking at the right ones (zero at the output - around 50v at the PSU but obviously less - and maximum possible at R8 or R7), I let it cook and see later again tonight.
Old 8th October 2019, 01:43 PM   #16093
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
F5 power amplifier
If they're from Mouser then I would expect they are genuine; more likely you just
had one that was damaged (perhaps in transit)?
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 8th October 2019, 01:48 PM   #16094
tooppy's Avatar
It can happen, no big deal, Mouser don't sell purposely deficient items !
As I knew these things happen, I ordered more items than needed.
For example I have a spare rectifer , fuses , Jfets, resistors and still one more of these caps.
Old 8th October 2019, 03:37 PM   #16095
Baobei is offline Baobei  United Kingdom
Just finished assembling my F-5, but I keep blowing the fuses when powering up (I don't have a Variac, so full on...). I tested the power supply before connecting the boards and it ran without a problem. I re-checked all the connections and P1 and P2 are all the way anti-clockwise (until they make this clicky sound). P3 is not installed as I don't have the measuring equipment.
See some pictures attached. Any idea where the problem could be?
Old 8th October 2019, 04:51 PM   #16096
zjjwwa is offline zjjwwa  Poland
zjjwwa's Avatar
F5 power amplifier
Did you try to power it up via a series old-tech filament bulb/halogen_lamp, of a wattage higher than the whole amplifier? The "soft-start" concept to fill up the filter capacitors, under load?
Old 8th October 2019, 05:23 PM   #16097
Hoopy Frood
F5 power amplifier
Baobei,
Are you using a slow blow fuse?
Can you please measure the resistance across R6 and R5? Are they close to zero?
If not, turn the pots P1 and P2 in the opposite direction until they are close to zero.
Then try powering up again.
Dennis
- NP 2002
Old 8th October 2019, 06:07 PM   #16098
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
As Dennis says, measure ohms across R6 and R5 and adjust the pots in whatever way is necessary to make that reading zero or very little. The pots don't necessary turn "down" by being turned anti-clockwise.
Old 8th October 2019, 09:45 PM   #16099
Thanks a lot guys! Measured R5 and R6 and it looks like I did turn them the wrong way around...
Add that to my list of silly beginner's mistakes.
I'll try biasing again when I can find time later this week hopefully.
Old 8th October 2019, 11:14 PM   #16100
flamethrower1 is offline flamethrower1  United States
F5 power amplifier
This is going to be helpful to me as I did not zero mine before I mounted them.
Anyway, looking forward to you getting yours going and your listening impressions
F5 power amplifierHide this!Advertise here!
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 39 2nd August 2019 01:58 AM
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2019 diyAudio
