F5 power amplifier
F5 power amplifier
Old 7th August 2016, 03:16 PM   #15191
EUVL is offline EUVL  Europe
Pictures of our matching setup, MOSFET heater block (insulation removed), and a special heater block for TO92 JFETs.
And the FET tester of our own design.
Patrick
xen-audio.com
Old 7th August 2016, 09:13 PM   #15192
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
My test setup:
Old 16th September 2016, 01:01 PM   #15193
Joca is offline Joca  Portugal
hi, any help is welcome
My recent build of the F5 has this simptoms:
Cold start - bias rises to 0.7v on both channels and stays there for 3 to 5 seconds and then go low to 0.60v after a while. this voltage is my bias setup after thermal equilibrium (1 hour) but i have flutuation between 0.595v and 0.625v
my dc offset is stable on both channels at 1mv
i have little hum on the speaker when i have my ear very very close. This hum seems to be related to the hum or noise i have inside the case near the rectifier bridge. I have the ixys diode and they get really hot. i can't touch them more than 2-3 seconds
https://www.digikey.pt/product-searc...DPG60C200QB-ND
thank you.
Old 16th September 2016, 01:59 PM   #15194
ColinA is offline ColinA  United Kingdom
Have you got anything connected to the input while testing?
Try re-arranging your wiring to see if it affects the hum.
Judge quality with your ears not instruments or simulators
Old 16th September 2016, 02:12 PM   #15195
nothing connected to the input. i am going to do the bias procedure again with the inputs shorted. My problem here is the inrush at cold start. Is it a common behavior?
so, it is normal the noise (mechanical?) inside the case?
if i can't reduce hum with wire arrangement, what else can be done?
thank you
Old 16th September 2016, 02:18 PM   #15196
qwertyl is offline qwertyl  United Kingdom
Do you have thermistor in series with transformator?
Big toroids can buzz a bit. It helps to have 2 separate rectifier bridges...
Old 16th September 2016, 02:21 PM   #15197
labjr is offline labjr  United States
IXYS diodes or bridges can fail easier than cheapo bridges. You have to limit inrush current.
Old 16th September 2016, 02:34 PM   #15198
I have two thermistors in series with the primary.
An externally hosted image should be here but it is no longer accessible. Please upload images instead of linking to them to prevent this.
Old 16th September 2016, 02:40 PM   #15199
sangram is offline sangram  India
It is normal for bias to start off little higher and back off as the thermistors start reducing the gate drive once the amp warms up.
It is normal for diodes to run hot. A heatsink is absolutely needed as the standing current is pretty high. You can expect about a watt for every ampere of standing current through the diodes, which makes them run hot. Add to that the temperature inside the case, and they could be quite toasty. If your fingers are not blistering, it's under 80 degrees which is okay for the diode, if not your fingertips.
Old 16th September 2016, 04:52 PM   #15200
Try turning the transformer a bit and re-tighten.(Not too tight.)
Try some rubber or cork sheet under the transformer.
By the way, nice tidy build.
A suggestion from my troubles.
Take the power from the rectifier board via connector blocks to the amp boards.
Then you can take one out of circuit without de soldering wires.
F5 power amplifierHide this!Advertise here!
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 39 2nd August 2019 01:58 AM
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2019 diyAudio
