UGS Power : it's U.P.
Old 15th October 2018, 01:22 AM   #371
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
think AB
rails are 23Vdc
say that output swing is few volts shaved from that ....... so 40Vpp, roughly
twice that, amp being differential/bridged , so 80Vpp
in my book, that's exactement 100W/8R
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th October 2018, 01:57 AM   #372
Luke is offline Luke  New Zealand
UGS Power : it's U.P. Send a message via AIM to Luke
sorry, I got 25 w unbalanced from 23v rails and doubled it for balanced as it has twice swing. This is wrong.
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 15th October 2018, 05:42 AM   #373
neno70 is offline neno70
ok thanks to everyone, I did not know this project ...
Old 15th October 2018, 05:50 PM   #374
P.S. with this end you must use only balanced connections, or you can also use unbalanced (rca) ?? THANK YOU
Old 17th October 2018, 11:48 PM   #375
aspringv is offline aspringv  Australia
I believe you can bridge one of the balanced connections to ground and you're good to go; albeit at a worse performance level.
I do have to say this is a doozy of a DYI project. A bit beyond me, so I'ts probably just as well I've never been able to get the boards or gerbers
...and I've still the UGS pre to do one day... (must learn to smd solder!)
Old 18th October 2018, 12:56 AM   #376
Zen Mod's Avatar
it is possible to use/wire any of inputs for SE/RCA
also , it is possible to use/wire outputs for both SE and BAL , and use either or both in same time
Old 21st October 2018, 12:45 PM   #377
hi all, I'm looking for transistors 2sk389bl and 2sj109bl on ebay are still there but at very expensive prices, there are alternatives to replace them?
Old 21st October 2018, 01:08 PM   #378
Zen Mod's Avatar
2sk170 and 2sj74
Sticky thread on top of forum
Old 21st October 2018, 11:58 PM   #379
Or better yet!
Linear Systems Matched LSJ74/LSK170 JFET pairs (Grade B) – diyAudio Store
Old 22nd October 2018, 05:59 PM   #380
Originally Posted by aspringv View Post
hello, ok ... but, question, the 2sk389-bt and the 2sj109-bt year 7 pins in the gerber file of the pcb and so .. while the LSJ74 / LSK170 JFET in the year only 3 .... are they okay? thank you
UGS Power : it's U.P.Hide this!Advertise here!
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 08:38 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 06:10 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 06:49 PM
