Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Balanced cable and RCA connector: how to wire them?
Old 3rd December 2019, 10:20 AM   #21
BvOsch is offline BvOsch
Perhaps I should have been a bit clearer in my post as the cable is not ready to be used, and still needs the RCA plugs to be soldered at both ends of the cable. Hence my question what the best way of soldering these connections is, considering I have a 4 core and ground microphone cable. What I understood from previous posts is that it is better to use inner cores for RCA signal and ground, and connect the ground wire to the same RCA ground at the receiving end of the cable. I am not sure if my understanding is correct and just wanted to double check this. Another option I guess would be to connect the ground wire to the chassis of the subwoofer and/or chassis of the Amp. What would be best practice I guess is my question.
Old 3rd December 2019, 02:03 PM   #22
Speedskater is offline Speedskater  United States
Speedskater's Avatar
I would wire it:
one conductor> pin to pin
shield/screen and the other three conductors> shell to shell
that's a lot of wires in a small RCA connector.
So if the shield/screen is a heavy braid, you might cut some of the spare conductors off at both ends.
Kevin
Balanced cable and RCA connector: how to wire them?Hide this!Advertise here!
will 30awg wrap wire terminate into rj-45 connector? riotubes Parts 0 28th September 2007 11:05 PM
How do I wire a balanced to 5-way binding post? guitaro Multi-Way 3 5th April 2006 01:34 AM
Finished my DIY Copper foil speaker cable, what connector to use? Guijs Everything Else 4 19th October 2005 11:31 PM
How to wire a Ixos Gamma 7 bi-wire cable mangalchacha Multi-Way 1 13th April 2005 03:58 PM
PS cable and connector rif Parts 3 1st February 2003 05:35 PM
Copyright ©1999-2019 diyAudio
